ECM Synchronika drain pan upgrade - Espresso machine drain plumbing - Page 2
jmbinette (original poster)
#11: Post by jmbinette (original poster) »
I thought I originally tested it "hard" but you're right I have a TH < 100. I just setted it to 3 (hope this is the right way)
thanks for noticing !
adcampo
#12: Post by adcampo »
Very cool. Thanks for sharing.
Are you saying the 5/8 ID is too narrow to drain quickly?
I just ordered my Sync and evaluating how to best plumb it. Draining seems to be a bit trickier than getting water to the machine. I found an adapter to connect the drain tube to my dishwasher:garbage disposal drain.
#13: Post by jmbinette (original poster) » replying to adcampo »
Well I guess it depends on your setup but for me it was not draining properly. Small ID and poor slope was making it almost impossible to drain to the back of my countertop and then all the way to my p-trap.
Maybe another Synchronika owner could chime in ..
adcampo
#14: Post by adcampo »
I just sent your design to my library for 3d printing. Thank you.
I'm going to do your exact set up, but with the Clive softer.
One question, is your drain line a 1" ID to a 1.5" drain adaptor?
#15: Post by jmbinette (original poster) » replying to adcampo »
Exactly, this is a 1.5 drain with a screw connection to another barbed hose screwed adapter 1" ID
adcampo
#16: Post by adcampo »
Awesome thanks. I've been trying to figure this out for the past couple of weeks. Very helpful!
From the picture, it looks like you tapped in to the main sink drain line vent stack. Is that right?
#17: Post by jmbinette (original poster) » replying to adcampo »
No, P-Trap, see previous post :
adcampo
#18: Post by adcampo »
Ok, so i see you built a p trap going in to the main sink drain line?
Did you leave some slack to be able to move the machine for cleaning underneath?
kray
#19: Post by kray »
Maybe I missed it, but what is the hole diameter you drilled in the counter top? You left a nice amount of room for both lines without going too big.
adcampo
#20: Post by adcampo » replying to kray »
Good question. I'm guessing it's a 2" hole.
