ECM Synchronika and Profitec Pro 700 Steam Upgrade - Page 2
Unless you're steaming for big bowl lattes, i think the standard wand with 4 hole tip is more than adequate on these machines . I can't see it being a cheap upgrade unless it's subsidised by ECM or Profitec. The PID controllers go for $250 here in Australia, plus a new safety valve $30-50 , plus labour, which could be a bit given the PID location behind the brew boiler, which means you have to virtually remove it to replace the controller. I'd allow 1- 1 and a half hours labour for changing the controller and testing etcJayBeck wrote:The Pro 700 (the Pro 500 was not in the video) comes stock with a 4 hole tip. The Synchronika comes stock with a 2 hole tip. It's not staged. In fact, if they had used a 4 hole tip, the milk would have come to temperature sooner. LMLM / GS/3 'steam' is no longer an advantage over these 2 machines with this upgrade. All the extra money buys you now is faster heat up time and commercial capabilities for pulling shots every 45 seconds whereas these machines need a 60 second rest to be temp stable.
I wonder what the cost is going to be to upgrade old machines. I would be shocked if it was more than $150-200 which would be worth it IMO if you make milk based drinks.
- bluesman
Did you remove the "no-burn" liner? It makes a world of difference. I ordered the 4 hole before removing the sleeve, but I removed the sleeve before the tip arrived. The 4 hole with the liner in place is no match for the 2 hole without it. The location and angulation of the 2 holes in the stock tip work incredibly well in my hands with the liner removed - the 4 hole stretches a bit faster, but I can't seem to get the texture of the foam to be as lush as it is with the 2 hole.felyko wrote:I have the opposite experience. The two hole tip on my ECM is close to useless, so I use a 4 hole steam tip which provides a steady whirlpool. Perhaps your 2 hole steam tip is of a different size.
- felyko
I think most people will do the upgrade themselves so labor isn't involved. I'm expecting the upgrade to be around $170 USD, but that's just my guess.kitt wrote:Unless you're steaming for big bowl lattes, i think the standard wand with 4 hole tip is more than adequate on these machines . I can't see it being a cheap upgrade unless it's subsidised by ECM or Profitec. The PID controllers go for $250 here in Australia, plus a new safety valve $30-50 , plus labour, which could be a bit given the PID location behind the brew boiler, which means you have to virtually remove it to replace the controller. I'd allow 1- 1 and a half hours labour for changing the controller and testing etc
- felyko
No, I did not remove the no-burn liner.bluesman wrote:Did you remove the "no-burn" liner? It makes a world of difference. I ordered the 4 hole before removing the sleeve, but I removed the sleeve before the tip arrived. The 4 hole with the liner in place is no match for the 2 hole without it. The location and angulation of the 2 holes in the stock tip work incredibly well in my hands with the liner removed - the 4 hole stretches a bit faster, but I can't seem to get the texture of the foam to be as lush as it is with the 2 hole.
The steam pressure valve is probably a $10 part. But they will most likely charge a lot for the PID - which is annoying because it should be an easy software update, as opposed to replacing the whole thing.felyko wrote:I think most people will do the upgrade themselves so labor isn't involved. I'm expecting the upgrade to be around $170 USD, but that's just my guess.
- felyko
It's quite possible that the PID is indeed re-programmable but most people will not have the necessary equipment and skill to do it, so the only option is to sell a new PID. The old PID was $130 or so.
It would be nice if they subsidized the price by allowing you to send the old PID back.
Looking at it the same way - happy with performance, but may upgrade at some point.mike guy wrote:Interesting. I am happy with the steam performance on the syncrhonika but I will probably spring for the upgrade kit if it's reasonable.
Does the new PID just allow higher set temperature compared to the old one?
How high does the old one sets to?
Alternatively, have it done when it's in for an annual service.felyko wrote:I think most people will do the upgrade themselves so labor isn't involved. I'm expecting the upgrade to be around $170 USD, but that's just my guess.
