Dalla Corte 58mm Kit - Page 4
Quoteing from the article "...The unique design of our portafilter is ideal for a cup of true Italian espresso ...". Does it mean it is not that ideal for modern 3rd wave espresso?
I think you have a point there. If you use a light roasted SO, ground very fine, dose 20grs, it will only choke with a narrow, high puck. You need a larger diameter to decrease puck height and get the water through.
So I don't think a 54mm nore a 58mm will always be better. It depends on your dose and grind. A bar dosing 14 grs of traditional blend will serve a better double espresso with the smaller basket diameter.
Yes, light roasted SO. I dose 18g in h30 basket, fine grind, longer (14s at 4g/s flow rate) or long (27s at 2g/s) preinfusion.
The Ethiopian is have now from friedhats.com I dose 18grs in 30mm basket, PI 12s on 3ml/s. I'll try longer. Which flow do you use after PI?
7.6g/s factory default (max). I have no Mina, but FP modified Studio, so can set "only" 2 flows plus 3rd flow is 7.6g/s factory default, and any time period combinations of the flows.
Go to Ebay Dalla Corte bottomless portafilter is EE 1098.21, from Edesia Espresso. If in the US you need to purchase via eBay.
