Cutaway of La Marzocco saturated grouphead - Page 2
malachi
#11: Post by malachi »
Cool.
So the Stainless replacement blocks are a easy retrofit. Very nice.
yeah - the flowmeters and the solenoids/pressure release are totall bulls**t.
Then again, the latter is true of most other machines as well and I'd never buy an auto machine, so...
What's in the cup is what matters.
barry
#12: Post by barry »
y'know, i never mess with the diffusion blocks, so it hadn't occurred to me to replace them with the stainless versions. that just got put way up on the list of things to do.
--barry "bought a welder today"
malachi
#13: Post by malachi »
I love the idea of the stainless replacement blocks.
Figure a set of them, plus Terry's PID retrofit kit... a semi-auto Linea starts looking pretty good!
And if you really have a solution for the whole solenoid mess - then it starts looking REALLY good.
barry
#14: Post by barry »
current scheme:
retrofit PID in custom replacement housing, with real-time brew temp display (not just boiler temp);
retrofit preheat;
solenoid/flowmeter reconfiguration;
variety of... "novelty" housing designs.
things are progressing slowly, but they are progressing. being able to zap metal parts together at will should speed things up a bit. of course, now i'm bumping up against the insane holiday season.
malachi
#15: Post by malachi »
barry wrote:solenoid/flowmeter reconfiguration;
would love to figure out a good solution for the 3-way valve location nonsense. if you have a plan...
AndyS
#16: Post by AndyS replying to malachi »
Are you familiar with Paul Pratt's modification? He put the body of the 3-way inside the group neck. Along with some of the other stuff that he did, it sort of brings the Linea up to the GS-1 standard. :-)
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
HB (original poster)
Admin
#17: Post by HB (original poster) »
malachi wrote:would love to figure out a good solution for the 3-way valve location nonsense. if you have a plan...
A quick recap for those following along who aren't familiar with the "valve location nonsense," at least as I understand it.
The multi-group La Marzoccos share a single rotary pump. Brew water is delivered to each diffusion block via a copper tube that momentarily exits the group, at which point a solenoid controls the flow, then re-enters to complete the pathway. Problem is, that little dash outside loses precious heat, and partially explains why barista competitions adamantly insist competitors flush the grouphead (not just to clear the dispersion screen, but also to clear the cooler water from this out-of-boiler portion of the delivery tubing).
For automatics, the situation is worse. A flowmeter works like a water wheel, spinning as the water passes to calculate the volume. There's a separate flowmeter per group, and once again, the brew water takes the long way home to pass by the flowmeter outside the group to reach the diffusion block (a single-group automatic wouldn't have this concern because the flowmeter is installed immediately after the pump, it isn't metering brew-temperature water, and thus doesn't contribute to heat loss). These two design choices earn the ire of those seeking uber-stable brew temperature.
(corrections are welcome)
AndyS wrote:Are you familiar with Paul Pratt's modification?
Very cool. Having only one group to deal with does simplify things though, which makes me wonder: Do any cafes use several well-capable one-group machines instead of a multi-group? Taking one machine offline for maintenance would be a lot easier. Or it is just a question of added space and potential maintenance (i.e., more parts means more potential failures)?
barry
#18: Post by barry »
HB wrote:partially explains why barista competitions adamantly insist competitors flush the grouphead (not just to clear the dispersion screen, but also to clear the cooler water from this out-of-boiler portion of the delivery tubing).
clearing the screen is the purpose of the flush. dumping water for a warming flush is a complex issue; it's not quite as straightforward as the cooling flush on a heat exchanger machine. if it was just the water in the exterior tubes that needed to be purged, that wouldn't be so difficult as it's not much water. the problem is the tubes themselves, and the solenoid body, and the flowmeter body, all need to be brought up to temperature before the water flowing through them can hit the coffee at the desired temperature. how much water to flush? a big "it depends".
AndyS
#19: Post by AndyS »
HB wrote: Do any cafes use several well-capable one-group machines instead of a multi-group? Taking one machine offline for maintenance would be a lot easier. Or it is just a question of added space and potential maintenance (i.e., more parts means more potential failures)?
Some people feel that the LMs get better as they step up in size from one to two to three groups. Bigger boilers run more stable temps, they say. Obviously, this doesn't solve the problem of the brew water flow path outside the temp stable zone.
-AndyS
malachi
#20: Post by malachi »
While the 3 group machines have a bigger boiler, the issues with the length of the heating element make one of the groups nearly useless.
It looks like Paul's mod is similar to the Hybrid group design. Very cool.
That's the obvious solution but as Barry pointed out earlier, it's a PITA for servicing. And given that most folks seem to step down to a very small gicleur, servicing is actually something to be concerned about (small gicleur plus updosing equals potential service call).
I worked on a machine for a while that had the Blackwell/Schomer banjo tube mods done and actually found it to be far more stable. Of course, you want to talk about service PITA?!?
