Brita Purity C Quell filters
sllo
#1: Post by sllo »
Anyone has any experience with Brita Purity C Quell filters?
My Kh is 125ppm and Gh is 107ppm, is the brita going to lower my tap water Kh and Gh to a range that will prevent scale build up?
Al deHyde
#2: Post by Al deHyde »
I don't have one, but eliminating (or reducing to some desired level) limescale is one of the things these filters are designed for.
Data sheets are located here:
http://www.espressomechanics.com.au/Acc ... brita.html
Don't know if these will be helpful to you or not but seem to contain all the info you need to calculate total capacity, desired 'bypass settings', filter lifespan at your water's hardness, etc.
Hope that helps a little.
