Breville Dual Boiler Mods and Maintenance - Page 105
luvmy40
#1041: Post by luvmy40 »
Munchies wrote:I am curious at what point should I be doing preventive maintenance? replacing o-rings and such...
annually or wait for something to break?
Bi annually at the very least. I have decided to replace all the o-rings annually in mine as I found a couple leaks last month by visual inspection before I could hear them. As *sigh* stated, it doesn't take long and the o-rings are cheap.
BaristaBob
#1042: Post by BaristaBob »
I agree with the others on preventative replacement of the 007 o-rings. I did it the hard way...one by one as they leaked. After replacing a standard silicone o-ring for a second time, years ago, I moved to AFLAS o-rings. All (around 15 of them) my 007 o-rings are AFLAS and not one has failed, some are as old as 5 years. They are not as easy to compress and get to seat. I found that using a small amount of food grade grease works well to get them in place. IMO, well worth the up front effort to "never" replace them again!
* "never" is a strong statement, but time will tell.
lancealot
#1043: Post by lancealot »
I have had a similar experience with AFLAS o rings in my BDB.
Munchies
#1044: Post by Munchies »
thanks for advice!
you mind posting links to the proper sizes of these AFLAS rings, food grade greasy and the tools i might need?
sternalot
#1045: Post by sternalot »
Recently replaced the pump on my Breville and the hot water dispenser intermittently spits/sprays when dispensing water. Anyone know what might be going on? Thanks!
Munchies
#1046: Post by Munchies »
Seems like Breville updated some points of failure..
Hopefully no need for o ring replacements now.
lancealot
#1047: Post by lancealot »
Wow. That's what I'm talking about. When did you buy this one? Any clue what the production date is? These machines have been out of stock on Breville's USA site for a while now. I wonder if all new machines will have this revision!
BodieZoffa
#1048: Post by BodieZoffa »
Can they make those things any more flimsy? Thing looks like they have joined forces with Fisher-Price. Looks as if the rear housing has bowed simply by lifting the lid.
BaristaBob
#1049: Post by BaristaBob »
Munchies wrote:Seems like Breville updated some points of failure..
I'm interested in the production date like Chris.
I think it's on a sticker on the housing that holds the water tank. I believe mine said 1525...meaning 2015, week 25.
Munchies
#1050: Post by Munchies »
Manufacture date around mid 2022 (32nd week)
