I have the BDB and noticed deviation this morning, i.e. 15gm dose with output varying form 24gm to 34 gm at 30 seconds.
As I use my leveling device as a tamper as well, I chalk this up to tamping variance, but perhaps I'm wrong.
As I exclusively make milk based drinks, this variance does not seem so critical to me from a taste POV, but I do prefer the shorter pull.
Breville Dual Boiler: Inconsistent espresso shots - Page 3
- slipchuck
Honestly that variation wouldn't be something I would be too concerned about if the shots taste fine
I think too much time is spent on details and not the taste factor
Randy
Randy
Which grinder do you have?SAllen wrote:I have the BDB and noticed deviation this morning, i.e. 15gm dose with output varying form 24gm to 34 gm at 30 seconds.
I totally agree that the taste is what is important. I do notice, though, that the slowest of my shots can have an harsh taste and a subtle "chemical" smell, even in a milk drink. So I would at least like to be able to reduce the variation a little.
Thanks for all the replies so far. I haven't been able to reply to all. I will definitely do a series of backflushes and pay attention to the pressure gauge.
I use the Sette 270wi.
Testing this morning, it seems that what I think is a relatively slight variance in the tamping causes the amount variance (27gm vs 37gm in 30 seconds).
Amusingly, when I ask my wife which she prefers, she always says she slightly prefers the first cap, which can be either the longer or shorter shot- there's nothing like that first taste when you wake up.
I too have experienced this with the BDB and Niche. I always suspected BDB was to blame but I think it's likely Niche isn't aligned well. When is the last time you cleaned it? What fixed it for me was a complete tear down and clean of Niche and when putting back together tightening the bolt way tighter than ever before (to the point I thought the NFC disc was going to crack). Once my bolt was this tight, my grind range doubled (from grinding 6-10 up to 18-20). I also gained much more consistent shots.
Tamping pressure probably wouldn't make that much difference--that may have been a fluke.SAllen wrote:Testing this morning, it seems that what I think is a relatively slight variance in the tamping causes the amount variance (27gm vs 37gm in 30 seconds).
For sure! I relate.SAllen wrote:Amusingly, when I ask my wife which she prefers, she always says she slightly prefers the first cap, which can be either the longer or shorter shot- there's nothing like that first taste when you wake up.
I'm talking more generally now and not to you specifically, but one of the things I've learned over the last eight years is that I used to be much too quick to call out patterns. I realize now it may take a lot of time and many shots to get a good sense of what's going on. For example, I've now pulled several hundred shots with and without a PorcuPress, and I'll still not ready to commit to a generalization. I'm doing the same with a BPLUS filter on top of my puck. And I've done the same for years comparing grinders. Often a pattern I think I'm seeing doesn't hold up over time.
