Breville Dual Boiler, five+ years on - Page 133
Anyone know what size screws are used on the U-clamp that holds the steam valve in place. I was working on flipping my valve seals and despite trying extra hard to keep track of everything, have managed to lose both of those screws .
Edit:
6-32 screws did the trick for future reference.
Edit:
I'm after some help.
I've got a Dual Boiler that keeps on tripping. The only o-ring that seems to be leaking to any degree is the one on the left hand side of the steam boiler. Are there any guides or videos o line covering how to change this one?
Peering in, it does appear to have a bit of a build up of minerals on it, and when you hear a drip, the machine instantly trips.
It just looks quite a task to get to!
- lancealot
Hi Jim,
See the link below, it covers all the BDB mods and maintenance wisdom collected on this site.
The info you seek is in Post 1, Item 3, Last Paragraph.
Breville Dual Boiler Mods and Maintenance
Great, thank you!
Another q: what could be causing a loss of pre-infusion pressure? Shots pull fine otherwise, I just don't get any pressure at all during the first phase.
Solenoid?
Solenoid?
- lancealot
Could be a few things. Take a couple of hours and change the o-rings. Not just the one on the side, change the ones on the top of the steam and brew boiler too. After you are done, run the pump with out the portafilter to get all the air out of the system. Then put the grey silicone disk in the basket and pull a blank shot and see what happens. It is behaves normally, you are golden. If not, it could be the pump or the solenoid.
Ok so that was a nightmare!
Solenoid came off easy, clip on hose tricky to access but manageable, but the pipe and brass fitting was fused in really badly. So much so that I tore the pipe at the ferruel getting to out.
Had to snip the end of the pipe, cut off the fitting (dropped the ferruel in the machine at one point argh!) o-ring on, but getting it back in and clip on was very tough. Finally managed it, all reassembled.
No more tripping, and no leaks that I can see, but now I have no steam... I'm getting the dreaded 3 beeps when I open the valve.
Anyone got any tips for sorting that??
Seems to have corrected itself! I just left the machine on for a couple of hours and the problem vanished. Perhaps it was an airlock in the boiler or something...
Either way, steam working, and no more leaking or tripping. Woot!
Now just the lack of pre-infustion to sort. I've got a new solenoid on the way, so wonder if that will help.
Does the pump come on at all during PI?Jiiim wrote:Seems to have corrected itself! I just left the machine on for a couple of hours and the problem vanished. Perhaps it was an airlock in the boiler or something...
The pump during PI on my BDB would sometimes not kick in. If I short cycled the pull and started it again immediately, it would kick in and run as it should. When I fragged the steam boiler doing the dreaded de scale, they sent me a new machine so I never found out what the cause of the glich was.
It doesn't sound like it comes on at all during PI.Does the pump come on at all during PI?
Is it the same pump that does this, or is there a separate one for the PI?
It's the brew pump. It runs at a lower pressure for PI then kicks in full tilt for the brew.
