Are your sure you are hitting valve-stop and not the mechanical stop that is part of the knob-chassis interface? Also, how long does it continue dripping after valve closure? Remember, without the pump running, there should be nothing driving water flow. That means, it should stop dripping when whatever is in the tube has dripped it's way out.jlixfeld wrote:Indeed, I was able to get it off. Unfortunately though, adjusting the knob on the spline didn't have any effect on the dripping issue.
When the machine is cold, it doesn't start dripping until after it's heated up and the knob has been used to start hot water flow. Once the water is shut off, it starts dripping a couple of drops per second.
If removing and cleaning the valve won't resolve the issue, is there another way to resolve it?
-Peter
