Breville Dual Boiler, five+ years on - Page 113
Yes. That filter works great. A simple under-sink install. But as with all filters it eventually loses effectiveness. And you need a test kit to determine when it's time to replace the filter. And the filters cost $55... if you shop carefully. I do get about two years use out of a filter though. And the test kit is $75 although you get a hundred uses or more out of it. My machine is plumbed, so I have to put up with that bother. Alternatively, distilled water with a pinch of baking soda (80mg/quart or so) is easier if you are not plumbed. That's what I use for my machines that are not plumbed.walleye wrote:Thanks. I'll give this at try.
And I'm going to tackle the hard water issues. I'd like to avoid a whole house water softener. It looks like you've used this in the past:
https://www.allfilters.com/undersinkfil ... m-esp124-t
Has that been ok?
-Peter
LMWDP #553
A little late follow up.. Found the source of the leak and replaced all the other ones on the steam valve as well. Thanks everyone for your help!
Has anyone tried leaving the screw out of the lever that actuates the steam valve? It seems to be staying in for me without much effort.
Kind regards,
Karan
Karan
Congratulations.new2espresso wrote:A little late follow up.. Found the source of the leak and replaced all the other ones on the steam valve as well. Thanks everyone for your help!
I have not left that screw out. For me, the steam valve is a once every couple of years thing. So leaving out that particular screw is of little benefit. Unlike leaving out the screws for the top cover, which promotes frequent inspection.
-Peter
LMWDP #553
I'm seriously considering one of these. Any reason not to? Not my favorite looks wise but that's okay. Thanks!
My quick summary...
Pros:
-Requires more frequent, but generally easy DIY servicing than some others
-Techno geekery: Has super precise temperature stability through multiple heaters and PIDs (not just one, like so many others)
-If there is ever a problem you can't tackle, for a fixed fee ($350-400) they will fix it for you. That fee includes shipping both ways AND they pack it for you, so you don't have to worry about that. If you pick your problems carefully, they won't want to fix it and will probably send you a brand new machine.
-It is a SUPERB platform for customization and tricking out. There is not a new and hot extraction technique that you can't make it do if you are of a tinkering and modding mind
-If you do like roasting, the precise, what you see is what you get, temperature setting is nice for dialing in
Cons:
-Requires more frequent, but generally easy DIY servicing than some others. If this is not your bag, you will have to consider forgoing the world class temperature stability for something else, or else buying something many times more expensive to get the same thing.
-Does not have that classic espresso steam punk look and feel
HTH
-Peter
Pros:
Cons:
HTH
-Peter
LMWDP #553
- Willinak
Peter, why the pinch of baking soda (sodium bicarbonate)?pcrussell50 wrote:Yes. That filter works great. A simple under-sink install. But as with all filters it eventually loses effectiveness. And you need a test kit to determine when it's time to replace the filter. And the filters cost $55... if you shop carefully. I do get about two years use out of a filter though. And the test kit is $75 although you get a hundred uses or more out of it. My machine is plumbed, so I have to put up with that bother. Alternatively, distilled water with a pinch of baking soda (80mg/quart or so) is easier if you are not plumbed. That's what I use for my machines that are not plumbed.
-Peter
Because overly pure water, like distilled water does not conduct electricity, and so the water level sensors might not work right. So you need to add something that won't cause scale but will allow for the sensors to work. You can also use 100mg/l of potassium bicarbonate, (or again 80mg/l of sodium bicarb). And this goes for all espresso machines, not just the BDB, especially ones with copper and brass, where potassium bicarb or sodium bicarb also helps promote the formation of a protective oxide layer over reactive metals. The BDB has stainless boilers so that's less important but still...
-Peter
-Peter
LMWDP #553
Hello Everyone!
I have been considering a used BDB for my first machine purchase. I have already read this entire thread. But, I was wondering if there were any BDB specific questions I should ask sellers?
Already on the list
Already on the list
- What type of water do you use
- IS your steam wand nozzle leaking
- What is your mx and cleaning routine
- have you descaled recently?
I just got one a few weeks ago and I would add some of the other incredibly well thought out features:pcrussell50 wrote:My quick summary...
Pros:
Cons:
HTH
-Peter
- Front filling water tank. Doesn't seem that special, but it's really nice to have.
- Front view water level window. I LOVE this.
- Wheels that extend and retract to allow you to move the machine easier. Though I find it's pretty easy to slide anyways.
- Auto on feature that I used to have to use a WIFI plug for.
- Super fast warm up. It's ready to pull a shot in 10-15 min.
The last time I tested it was 06:52, so I would say 7-8 min.nrcoffee wrote: - Super fast warm up. It's ready to pull a shot in 10-15 min.
Von meinem iPhone gesendet
