Breville Dual Boiler (BES920XL) Drain Tray Mod for Acaia Lunar Scale - Page 2
Thanks, man! For the money, it's a fun mod
LMWDP #672.
- jchung
Any concerns that the Lunar might end up sitting in water for an extended period of time?
I can write up something if you are interested.HH wrote:This is super cool Dave! Did you use the LMLM or GS3 tray? They seem to offer two different versions and I wanted to masker sure I got the correct one/they were the same.
Was there any difficulty with the Breville's moulded drip tray (ie under the metal grille)? If you're able to do a step by step guide or set of instructions for the mod that would be awesome... but if it's as simple as:
1. cut correct size hole in drip tray
2. Insert scale housing
Then that's all I need to know
Henry
LMWDP #672.
Sure. Do you have the exact same scale? If so I can make it customized to the Acaia Lunar like mine.
LMWDP #672.
I have the brewista, which I think would also fit nicely on the tray, but if you could show me for your Acaia I'm sure I can make it work!
Thanks,
Henry
Thanks,
Henry
Do me a favor and send me a photo of the brewista on the drip tray and I can help you out
LMWDP #672.
