Brass espresso maker
The only thing anyone can tell you absent description or photos is the value based on the weight of the brass.
LMWDP #730
- yakster
A picture would help and a description of its operating condition and maintenance record. Brass is a popular metal used with lever espresso machines.
-Chris
LMWDP # 272
LMWDP # 272
- truemagellen
I love threads like this. It is a mystery wrapped in a riddle wrapped in a wonton wrapper perhaps with cream cheese in it.
- HB
- Admin
Everyone's a comedian! I fixed the [img] tags in the first post so everyone can see the mystery brass espresso maker.
- baldheadracing
"Flip" dripper?
- C-Antonio
I cant tell if the spout has an ending with orifice or its an open spout with a cap (there might an hole on a cap too, one sees right away if it pops off or not)
It doesnt look like its a flip coffeemaker since it lacks any handle and it looks like its made to stay hanging onto something. Given the locking mechanism if you flip it it seems to me it would release. Then again if it was a flip type the boiler bottom would be opposite the half with the spout and there is a bit too much stuff on that end to actually be where the heat is...
Maybe a steam pressure coffeemaker, with a cap on the spout, travel type?
It would be nice if the pictures were of each side, tops and bottom and taken all apart... otherwise there is no way to spot any marking on it or even get how it works to classify it...
From those two pictures it could be even an oil lamp...
“Eh sì sì sì…sembra facile (fare un buon caffè)!”
- yakster
It's a nice, vintage miner's lamp. You can see a similar example below.
https://www.dreamstime.com/stock-photo- ... ge84557216
You fill the cap with water which drips onto calcium carbide rock in the base to make acetylene gas which provides a flame out of the spout of the bottom section. Acetylene provides a good white light for mining purposes. I've never seen one like this before so it took me a while to get it. It looks like there's a drip adjustment on the top to adjust the flame.
Calcium Carbide is also used in toy cannons.
https://americanhistory.si.edu/collecti ... s-and-hats
-Chris
LMWDP # 272
LMWDP # 272
- yakster
