Bezzera Mitica/Magica pump pressure 12 or 9-10 bar?
Thank you for your help already in my purchase decision. In the end, I am the very happy owner of a Bezzera Mitica (vibratory pump).
Now I have a doubt regarding whether or not I should adjust the pump pressure of the machine.
The machine came adjusted to a factory 12 bar pressure. I have read comments pointing that a pressure of 9-10 bar is preferred. So far, that is clear.
But, after careful reading, I am not sure whether my machine is measuring 12 bar "closer to the pump" and it would be closer to 9-10 in the puck (so I do not need to adjust anything), or the measure represents approx. the pressure in the puck (so I should lower it).
I am getting similar pressure reading with the blind filter and during extraction, if this means anything.
Any input will be greatly appreciated.
If you wish to set it to 9 bars, you will need to purchase a modification kit.
I've seen it working with 12 bars without issues.
- radudanutco
in the current parts breakdown manual for Magica (I owned a Magica for 2 years), there are two models of the OPV, at pages 8-9, TABLE 2A (up to 30.10.12), and at pages 10-11, TABLE 2A (from 31.10.12);
it appeared to me at the time, that the second version - the one which you probably have, on machines from 31.10.12, is easier to adjust for a lower pressure; without getting all those squeaking sounds!
actually, the Accessories manual does not include anymore the 9 bar OPV modification kit (which I've bought at the time);
you might try it, it's just a problem of unmounting the covers (6 screws: 4 on the bottom, and 2 on the left and right side, inside, up, front - (especially the last 2) you should only loosen them, no need to unscrew them completely);
lowering the pressure does not change dramatically anything in the cup, but does improve a lot against channeling - the machine would be more forgiving...
the pressure gauge is showing the pressure immediately after the pump, so yes, you do not see the actual pressure above the puck!
however, as I measured it with a DIY portafilter with a pressure gauge, the pressure above the puck is lower than the value measured by the POMPA pressure gauge, but with less than 1 bar!
it is worth mentioning that at 12 bar, the pump gives an 130 ml/min flow rate (2,1 ml/sec), while, at 9 bar, the pump gives a 260 ml/min flow rate (4,3 ml/sec), meaning that at 9 bar there is larger by 2x flow rate margin, than at 12 bar: that would affect some normale to lungo shots, as the pressure would decrease to about... 9 bar, if the flowrate through the puck would increase to, say, 3.5-4ml/sec!
Thanks. I have done the adjustment and no issues. Apparently new Bezzeras can be adjusted without squeacking noises.
One question, just to understand it. Say I am trying to get 40ml in 25sec, thus I need much less than a flow of 4.1ml/sec at 9 bar, or I will fill up the cup in just 10secs...
How does it work then?
