Bezzera Magica Arrived Wet
Hi
I just got my new bezzera magica from 1st Line. I am worry because it has arrive wet.
Does anyone has this kind of issue?
- johnny4lsu
Probably because they do some testing before sending it out.
- HB
- Admin
I've tested lots of new espresso machines from various sponsors. Some vendors bench test equipment before sending it out; they usually include a sheet of paper explaining why there may be water stains or some moisture. The same goes for some grinders, which may arrive with some coffee grounds. 1st-line is a sponsor and reputable firm. I'm sure it was bench testing that's the cause, but I would encourage you to contact them with your concerns and remind them to include a reminder.
Received my Magica 3 months ago. It arrived a bit wet too. I wouldn't worry about it too much.
- Sponsor
Bezzera tests every machine with water. It is impossible to remove all the water. As the machine tumbles in shipping, water will exit the vacuum breaker valve. And, a little water seems like a lot!Marybel wrote: Hi
We ask that you let it air dry for 24 hours minimum outside of the box.
My bezzera is working great! I called 1st line equipment and they explained me about the test they do. Thanks!
Do you know for how long the machine can be on without being used?
thanks!!
1st-line wrote:Bezzera tests every machine with water. It is impossible to remove all the water. As the machine tumbles in shipping, water will exit the vacuum breaker valve. And, a little water seems like a lot!
- Sponsor
Our recommendation for home use... if not being used within 2 hours, please turn off.Marybel wrote:My bezzera is working great! I called 1st line equipment and they explained me about the test they do. Thanks!
