Bezzera BZ13 slow build up of brew pressure
Hi all,
Recently I am very some problem with my 2 year old BZ13.
Please watch this.
http://www.youtube.com/watch?v=UVyq7lwiIKk
The brew pressure build up is very slow. Any clues on what the problem is? Is it a dying pump?
Also in the past, after u press the button after the shot is pulled, the manometer needle will jump back to 0 almost immediately. But now it just moves back slowly.
Thanks in advance.
Erwin.
Please watch this.
Thanks in advance.
Erwin.
- another_jim
It sounds like the pump is fine; it looks like the gauge is slow.
Jim Schulman
You are right. I just replaced the pump and the problem is still there.
What are the possible issues?
1) Faulty gauge?
2) Solenoid Valve?
advice needed!
Thanks!
Erwin
1) Faulty gauge?
2) Solenoid Valve?
advice needed!
Thanks!
Erwin
My guess is it's the gauge. If your solenoid valve were sticky, I would still expect to see a instant drop to zero, albeit delayed. (Water is incompressible, so the pressure will instantly diminish even at a partly open exhaust port of the solenoid.)
Bert
Hi all,
Thanks for the suggestion.
If I were to take out the pressure gauge. Can I service it or do I need to replace it?
Thanks!
Erwin
Thanks!
Erwin
I am not sure what you could possibly do to service the gauge. It is basically a needle that moves with the compression force of a spring that balances the brew pressure. I would replace it.
Bert
- slipchuck
Besides the gauge, how do you like your Bezzera?erwinseow wrote:Hi all,
Please watch this.
Thanks in advance.
Erwin.
It rocks! Compact in size and warms up extremely fast. I had had it for 2 years+ and have pulled thousands of shots with it. I use it in an office environment and so far so good.
The only issue that I had so far was the joystick of the steamwand. The design is very simple made the parts worn out with high usage. So I replaced the worn parts. Quite easy if you are a hands on person.
Love it!
Love it!
Hi all,
How do I know that this problem is not due to the OPV?
Thanks in advance!
Erwin
Thanks in advance!
Erwin
A sticky OPV due to some deposit is not an uncommon glitch, but it usually shows as pressure oscillations, not a slower ramp up or ramp down per se.
Bert
