What to do with 8 grams of beans left over?
Came to the end of a bag of really great beans and I have 8 grams left.
Generally, I'll mix the tails of one bag with whatever is coming next. But there are times that this doesn't work. In this case, I have some really great (and pricey) beans left. But they need a really fine grind. Unfortunately, the beans I just got two bags of, need a really coarse grind and very different extraction. So I don't think combining them is going to work out.
Kind of silly, but dang, what to do?
- Denis
Cupping. You find the recipe.on youtube of Tim wendelboe.
8 g coffee with x15 quantity water.
Use a single basket.nuketopia wrote:Came to the end of a bag of really great beans and I have 8 grams left.
Another vote for thisDenis wrote:Cupping. You find the recipe.on youtube of Tim wendelboe.
LMWDP #748
I make cocktails with them. 5g of this.. 7g of that.. whenever I scrape together about 20g in total, I do pour-over with it.
Sometimes it's mehh.. but quite often you can be pleasantly surprised. I think part of it is getting away from monotony of familiar tastes.
V60 is far more forgiving than trying to nail an 8g single shot, assuming you usually pull doubles..
Yeah, if I had dialed in already, I'd try a 8g shot. It would take a couple of tries to dial in a single, so no go.
I just take and mix with enough whatever comes next to make a dose. Some of my best flavors have been screwed up blends like this. Even with the difference in the next origin it might surprise you. I wouldn't mix them in an entire bag though. Whatcha got to lose?
How about an inverted aero press or another filtered immersion brewing method? Easier to drink than cupping but the same idea that your brewing method is largely independent of the dose / yield
I alternate regularly between 7g singles using a La Strada 7g basket and doubles using a VST 15g one, using 7g in the former and 15g in the latter. I know from experience that the single requires a grind one tick finer on my Kafatek Flat. As a result, once I've dialled in the single or the double, I don't need to dial in the other.nuketopia wrote:Yeah, if I had dialed in already, I'd try a 8g shot. It would take a couple of tries to dial in a single, so no go.
(If I recall correctly, Denis says (or said) that one tick on the Flat is equivalent to two ticks on the Conical.)
