Saka Caffè in the States - Page 7
- Balthazar_B
Take a look at the precision baskets that Espresso Parts sells under their own label. FWIW, we find they work a little better with darker roasts than do VST baskets. Now if you want really low dose, you can look into La Marzocco single baskets -- which would necessitate getting a funnel and 41mm tamper...but worth the effort, IMHO.cskorton wrote:J
I'd love to try an IMS basket or some other higher quality lower dose basket. It does seem to make a noticeable difference.
- John
LMWDP # 577
LMWDP # 577
I've had the GMC many times and thinks its very good and its one of my go to's for making lattes in the morning but I feel that for it to be great it would be nice if it was more complex with thicker crema, maybe some high end robusta would make it better.TomC wrote: I've been bugging Phil at Caffe Lusso to make a 70/30 or 60/40 Arabica/Robusta blend recently.
Could the Lionshare be used for latte's (8-10oz milk)? I dose the GMC at 20g with that much milk.
- drgary
This thread is about Saka Caffe, so let's please keep the thread on topic. There are many mentions of GMC and Lionshare on this site that can be found with a site search.
LMWDP#308
LMWDP#308
- slybarman
Sadly, I used up the last of my Saka this morning. Back to Cartapani for now
- drgary
I had another delicious shot of Saka Caffe Gran Bar Top Selection this morning on my Cremina, using a Niche Zero grinder. The brew ratio was 17 gm in, 30 gm out. I like this blend the most when I pull it cool, which emphasizes the chocolate/hazelnut/orange sweetness of this coffee, which is wonderfully sweet without adding sugar. Mouthfeel was buttery thick. There's a long aftertaste of chocolate and almond. My probe is located near the back of the group, above the crease, and the start temperature was 185°F. In contrast, if I'm pulling a medium roast where about 202°F is an ideal brew temperature, my starting temperature on the outside of the group is 195°F, so I'm pulling this coffee about 10°F cooler. I will definitely be wanting more if anyone does a group buy. Yum!
LMWDP#308
LMWDP#308
Sadly finished up both bags of Saka, so I ordered a kilo of Filicori Zecchini Delicato to fill the void. I had very good luck with it in the past when I visited Bologna a couple years ago.
Regarding roast levels on these Saka beans, has there bean any discussion on the roast profiles of each? Is one considered Vienna, Full City+, etc...?
- slybarman
LOL - I just found an empty bag from Lionshare in my cabinet and did a search on here and found out I DID in fact try lionshare a year or so ago and didn't remember it at all. Man, I really have to start keeping a notebook of tasting notes for myself.slybarman wrote:I've only tried GMC, haven't tried Lionshare. I dose the GMC at 18g, compared to 14 for the Saka and pull it quite a bit hotter.
- drgary
There's a lot of pre-heating discussion about the Cafelat Robot. I'm using a very retro technique with Saka Caffe Top Selection, 100% arabica, updosing with 22 gm in, about 35 gm out and am pouring 197°F water into a portfilter that has not been preheated. I get the coffee equivalent of a rich chocolate brownie.
Ryan is generously offering another group buy opportunity, and this time I'm going to go for the all arabica Top Selection and the 20% robusta Gran Bar blend. Here's the link for the next group buy.
[FS] Saka Caffe Group Order V2
LMWDP#308
LMWDP#308
I cut my espresso teeth in coffee bars in Northern Italy, where the usual ratio is probably about 1:3. In Naples, I believe Ian is probably echoing the local formula. What I have never been offered, or seen advertised, in any part of Italy is a ristretto as it seems to be defined here in H-B (around 1:1 to 1:1.5). Has anyone else found such short shots in Italy?IamOiman wrote:13-14g for a double, 8g for a single
I go for a 2:1 ratio usually
- drgary
Maybe my technique isn't retro, then. But I like the way it tastes.
LMWDP#308
LMWDP#308
