Agtron ratings
I just found out about Agtron ratings but I'm seeing some numbers like 53/75. From what I've read, it can go above a rating of 75, but is the figure I quoted just saying that particular coffee is a 53 out of 75? Been looking at JBC coffee and they are the first I've seen to use this rating scale.
Ted,
The two numbers represent the range of the roasted beans in the blend.
Rocky
Rocky
They may represent whole bean and ground measurements.
Ah, that makes more sense. Thanks for the correction, Jonathan.
Rocky
Rocky
Why does whole bean and ground differ in roast ratings?
- another_jim
The surface of a roasted bean is darker than the interior. Since the whole bean rating is the color of the surface; it will be lower than the ground rating, which also includes the less roasted interior. The ground rating tells you how dark overall the roast is; the difference between the two ratings tells you how fast the roast went (the bigger the difference, the faster the roast). In general, faster roasts at the same ground Agtron level have more intense and more widely spread flavors; longer roasts have more focused, mellower flavors.
Jim Schulman
