I had signed up to tour the Slayer factory on Monday morning after the show ended. So, yesterday I took a wonderful bus ride down to the South side of Seattle to visit Slayer's gorgeous facility. I've posted a Flickr set of my tour photos here, but I thought I would share some annotated selections.
In the studio, we received a brief summary of Slayer's history and an overview of the functionality of the group, using their showroom machine (which happens to be a V2 Slayer).
Unfortunately, We didn't get to have any play time since they hadn't unloaded their equipment from the show, and so they had no grinders to use. So we moved onto the factory floor where the machines are assembled and tested. Here we got to see some of their larger components and also a number of machines under construction.
Looking into the factory floor from the studio.
Steam tanks, preheat tanks, and brew boilers for multigroup machines.
Detail: a ball bearing in the steam actuator. Over the top.
We got to examine their new V3 boilers in detail, which was really interesting. Here are a few details that I hadn't seen before.
The boiler has stainless steel tubes welded into the group. Here you can see the pickup tube (left) with a fitting for the machine's 0.7 mm gicleur. The pickup tube connects to the 3-way valve boss on the rear of the group neck. The tube from the right returns the water from the valve to the grouphead.
A side view of the 3-way valve boss on the rear of the group neck. Here you can see the port for connecting the pressure gauge on the side.
From there, Chris took us to their parts room, where they showed us a selection of their custom parts, such as actuators and heating elements (which are made of inconel rather than brass, which they claim makes them dramatically more robust against running with the boiler empty). One of the highlights was the needle valve assembly for the V3 group.
Call me uneducated, but I was kind of surprised that it really was a needle!
After we looked at the parts room, Chris, our tour guide, gave us a look at some multi-group Slayers being built. It's striking how nicely put together these machines are compared to many others I've had the dubious honor of working on. They really do seem to be designed by a technician who expects to have to maintain them.
Finally, we got the coup de grâce-a look at 4 or 5 of the single groups they're currently assembling:
Note the gicleur installed on the pickup tube-it draws water from almost the absolute top of the group.
The basic layout of the internal parts and plumbing was nearly complete. Also, we got to see the pump mounted in the rear:
mounted corner-to-corner on a pair of rubber isolation mounts, with a length of braided hose on the inlet side.
Quite a tour. A lot for me to soak in, to say the least. Chris wrapped up and said we were welcome to hang out for awhile and look around as we pleased, so my friend Jeff and I did that while everyone else left to go back to town.
Which was a good call. Jeff met Benny, their resident welding/machining expert, and seemed to be getting into the finer points of boiler welding technique. Meanwhile, I had returned to more closely examine the set of very incomplete single-group machines on the table in the middle of the factory floor. Devon, another Slayer guy, approached me and we started talking. When I mentioned that I was excited about these because I was expecting mine in about 5-6 weeks, he said, "Oh. You should come check this one out." He walked me over to the back of the room where he was bench testing the very first production machine. It was perched on a few 2X4s and still missing its exterior panels, but the group plumbing and most if not all of the electrical work was complete. Devon was able run the group and show a little bit about setting up the machine and manning the controller interface.
So I got a number of new details about the Slayer 1-Group that I hadn't read before. I posted those details separately in this thread.
