[SOLD] Wug grinder with 80mm Ditting LabSweet burrs (Canada)
Used espresso or coffee stuff you hope to sell or buy.
Bunkmil
Supporter
#1: Post by Bunkmil »
Hi there,
I am moving and unfortunately I need to do a bit of cleanup in my coffee gear. The grinder is almost new. No more than 10lbs of coffee have gone through the burrs.
Since I had no intention to put conicals the motor is a bit smaller than the one used for the standard version because I didn't need the dual rpm range. The rpm range on this unit is 400-700.
There is plenty of room to adjust the grind setting in the espresso range so grinding fine enough is definitely not a problem (actually seems better than the original Ditting grinder in this regard lol).
Here are a couple of pictures and there are more in the following album.
Asking $2300USD plus shipping. Located in Montreal, Canada
Feel free to reach out if you have any questions!
