[SOLD] Slayer v3 One Group
Used espresso or coffee stuff you hope to sell or buy.
lloydalvarez
#1: Post by lloydalvarez »
Selling my beloved Slayer. She is in great working condition and has been lovingly cared for and serviced by me since she was new. She makes about 2-3 espressos a day so not a lot of wear and tear. She makes a mean espresso and I will be happy to do a barista lesson/session with the buyer as this will have to be a local pickup in Brooklyn, NY. Among many things I can explain how to take advantage of the flow profiling that Slayer pioneered by using the needle valve and changing the brew pressure and temperature for different beans and roast profiles. She also has the best steaming power available rivaling any commercial machine to allow you to make the silkiest steamed milk for award-winning cappuccinos!
I promise it will make one of the best espressos you've ever had or you don't have to buy her ;-)
Has a new (much brighter) display from the newest version that now retails for $9500
Price: $6000 obo
Local Pickup in Brooklyn NY only
Includes all accessories:
58 mm bottomless portafilter with 20 gram double basket
Blind basket for backflushing
Teflon coated dispersion screen
Matching wood slayer tamper
Custom 3D printed drip tray that does not require plumb-in (the regular metal plumbed drip tray is included and has never been used)
Date built: 2015
Version: Single 1.7.1a
Power: 120 volts, 12 amps
Black finish with Silver Metallic legs
Ideal for coffee shops, restaurants, catering events, and more
Manual operation of the 3-position actuator allows total control
Pre-heat Coil - Stabilizes brew tank temperature
Power Saver Schedule - Automatically powers on and off
Shot Mirror - Improves visibility during extraction
Grind fine with restricted flow rate during pre-brew phase
Digital, touchscreen readout features backflush, timers, and access to all parameters
Dual tank system with steam or brew tank priority
PID temperature control, adjustable in 0.1° increments
Commercial portafilter with 58-millimeter, 18-gram basket
Wood handles and actuators
Hot water tap
Internal gear pump
18.5"W x 23"L x 13"H
Weight: 100 pounds (dry), 110 pounds (wet)
Brew tank: 1.1 liters
Steam tank: 3.3 liters
Pre-heat coil: 60.0 milliliters
600-watt brew tank heating element
1300 watt steam boiler heating element
Direct water plumb only
Certified ETL Sanitation* (conforms to NSF/ANSI Standard 4)
