[SOLD] Quick Mill Vetrano 2B Espresso Mach (Seattle/Portland)
The Vetrano 2B by Quick Mill features dual boilers, a quiet rotary pump, PID, and professional-caliber components.
Purchased in 2014. Several hundred dollars of upgrades including custom cocobolo steam/hot water knobs, lever handle, and Portafilter handle. Includes two additional portafilters, various filters, and espresso distributor. Pulled 2-3 shots per day. All water went through 3 stage filtration including water softener. Machine operates flawlessly and is fully plumbed and includes drain kit (it can also run off the tank). I would prefer to sell locally in the Pacific Northwest and am willing to drive to meet/deliver the machine within a reasonable area.
Technical Details
Height: 16.5 in
Width: 12 in
Depth: 18 in
Weight: 70 lbs
Housing Material: Stainless steel
Drip Tray: Stainless steel
Drip Tray Cover: Stainless steel
Drainable Drip Tray: Yes
Water Reservoir
Reservoir or Plumbed: Both
Capacity: 3 L / 101 oz
Material: BPA free plastic
Removable: Yes
Low Water Shutoff: Yes
Steam Wand
No Burn (Insulated): Stainless steel
Wand Movement: Stainless steel
Steam Tip Holes: 4
Optional Steam Tips: Yes
Controls Temperature: Digital temperature control
Brew Temperature Adjustment: Individual degrees (Fahrenheit or Celsius)
Steam Boiler Adjustment: Individual degrees (Fahrenheit or Celsius)
Display Type: LCD
Display Can Be Disabled: No
Integrated Shot Timer: No
Built-In On/Off Timer: No
Display Cleaning Reminder: No
Pre-Infusion: Yes, when plumbed in
Flow Profiling: No
Volumetric Dosing: No
Pressure Gauges: 2, pump pressure and steam boiler pressure
Cup warming tray Material: Stainless steel
Portafilters & Tampers Materials: Chrome plated brass, plastic handle
Type: Commercial 58 mm
Portafilters Included: 2 (single and double spouted)
Baskets Included: Single, double, and backflush disk for cleaning
Tamper Included: Temporary plastic tamper
Group head Type: E61, lever activated
Maintenance: Urnex Full Circle or Cafiza backflush detergent
Boilers Material: Stainless Steel
Brew Boiler Size: 0.75 L / 25.36 oz
Steam Boiler Size: 1.4 L / 47.34 oz
Boilers Automatically Fill: Yes
Insulated: Yes
Heating Element Access:Yes
Pump Type: Rotary vane
Recommended Brew Pressure: 9 bar
$1,599
Technical Details
Height: 16.5 in
Width: 12 in
Depth: 18 in
Weight: 70 lbs
Water Reservoir
Removable: Yes
Steam Wand
Steam Tip Holes: 4
Display Type: LCD
Flow Profiling: No
Insulated: Yes
$1,599
