[FS] Omega Data Logger Thermometer
Used and in a very good condition. If you are using any kind of temperature testing on your espresso machine, this is the ideal thermometer for the job. I used ut mostly with the Scace Device. Includes 2 Type K Thermocouples
HH506RA is a low cost, feature-packed, portable, digital thermometer that measures K, J, R, S, T, E and N thermocouples. The unit has datalogging capacity in the save mode of 128 samples with real-time data and in the datalogging mode of 16 sets, with a maximum data capacity of 1024 records. Easy to use set-up instructions allow the user to measure a broad range of T/Cs, MAX/MIN, AVG, REL, Hold Function, T1/T2.
- Dual input datalogger with RS232C communication cable and software
7 thermocouple types
Save data (128 samples with real-time data)
41⁄2 digit LCD display
°C/°F switchable
0.1° resolution
IP65 rated
Time, record interval, APO time setting
Abe Carmeli
