[SOLD] Nuovo Simonelli G60 grinder
Received in August 2018, fewer than 400 18g doses through it.
I bought it from Chis Coffee: https://www.chriscoffee.com/Nuova-Simon ... 21g60b.htm
It's a lovely grinder. Solid, very responsive to dialing in and stable once set. Nicely made and can be disassembled and cleaned without upsetting your settings. 60mm burrs, 12oz hopper, two programmable time-based settings. Not too big, should fit under just about any cabinet.
Also includes a custom-made acrylic base to sit between the front legs of the case and allow a flat, solid surface for a scale. You can then dose directly into a weighed portafilter -- I used a Decent Espresso PF cradle.
Selling only because I've moved to a single-dose workflow and it's no longer needed. If I had the space I'd keep it!
Located in Northern Virginia. $650 plus actual shipping, local pickup preferred. I do have the original shipping carton.
