[FOUND] Original Feldgrind or Similar
**FOUND, thanks to a fellow HB member.
*UPDATE - After more research, I think I would really like to find an original Feldgrind. I would also consider a Feld2, Aergrind, Kinu M38, or maybe a Lido 3 as well. I think the original Feld will be the right combination of size vs. portability with the old handle design that can be tucked against the body of the grinder.
Thanks again!
I would like to upgrade my travel/camping hand grinder and between analysis paralysis of the various options and availability, I thought I would check here first to see if anyone is looking to part with a: OE Lido 3, Knock Aergrind or Feld2, Helor 101, Comandante C40, or Kinu M38 or the like.
Basically, I'm looking for a consistent, easy to use, reliable, and portable hand grinder. I primarily use the Aeropress when camping, but would like to be able to grind doses of at least 25g for occasional pourover or french press duty.
Thanks!
Thanks again!
Thanks!
Versalab
