This one is 58.3mm so it fits perfectly on VST baskets
This tamper was designed to take one more variable out of making great espresso, consistent tamp pressure. The Espro Automatic Tamper is a piston action tamper that lets you know when you exert 30 lbs. of pressure. The handle depresses a bit and makes a subtle clicking sound when 30 lbs. of pressure has been applied. The base is a flat bottom and made of stainless steel, the handle is anodized metal.
Solid 1 lb tamper weight, perfectly balanced
Stainless steel base and anodized aluminum handle
30 lb force actuation
Factory calibrated - does not require recalibration or adjustment
Made in Canada
asking 50 USD$ plus shipping rate/import duty from Canada (provided uppon request).
