[SOLD] Bezzera BZ09
Selling my ultimate shotmaster tank Bezzera BZ09.
Never let me down, built from thick stainless steel, very reliable machine.
Electric heated brew group, excelent temperature stability and quick warm up time.
The Bezzera BZ09 is often referred to as the little sister of the famous BZ10. Like these, the machine is equipped with the traditional tipping valves and is otherwise very similar to the classic Bezzera design. As a single-circuit espresso machine, the BZ09 has a boiler that supplies the brewing group and steam plant at the same time. The specially equipped brew group heating ensures that the machine is ready for use after just 12 minutes of heating up. In addition, two heating cartridges are used, which, together with the internal thermostat, keep the temperature very stable. If the water level in the tank falls too low, the heating elements switch off automatically.
Quality at a low price
As usual from Bezzera, the BZ09 also relies on high-quality workmanship and high-quality materials. Inside, the espresso machine houses a copper boiler and a vibration pump, surrounded by a stainless steel housing. There is also a pressure gauge on the front, from which the pump pressure can be read.
https://www.bezzera.it/en/machines/bz09
Price $900 located in Orlando Florida but willing to crate and ship CONUS.
