[SOLD] Bezzera B3000AL lever
This Bezzera B3000AL is a compact commercial lever espresso machine. It's quite rare and it's a super efficient design with it's massive thermosiphon and very stable boiler. No issues pulling a wide variety of roasts since the preinfusion is controlled by a pressure regulator valve (adjustable between 1-6 bars depending on filter restrictions)
- CMA lever group
- Heat exchanger
- Direct hook up to main water line
- Auto boiler refill
- 4.5L insulated boiler
-240v 10a (most kitchen have 220v circuit available)
-2000w heating element
- Custom 3D printed drip tray if you don't want to use the drain
- comes with extra piston seals and group seals, hose, drain, etc.
- 2 original portafilters (one converted to bottomless), single and double filter basket + EPHQ14 basket which is a superb match with this group.
Dimensions: 17.5" deep / 14" wide / 19" high (29" with lever)
It's in good cosmetic conditions with minor rust spots on the frame near the drip tray and a few light scratches from normal usage. I did not do a complete rehaul since it's not needed at all considering the actual condition. I only isolated the boiler which brought the pstat cycle to the 4min off / 20 sec on range.
It's in perfect working conditions.
I'm in Montreal, Canada and would prefer finding a local buyer. I will consider shipping if it makes sense.
Asking price is $1200 USD
This is her in action:
http://www.youtube.com/watch?v=ItM6YJ_IJ8Y
- CMA lever group
- Heat exchanger
LMWDP #592
