Upgrades:
- Lelit Flow Control
- Eric's E61 Thermometer
- Luminaire Shot Timer (works 99% of the time, I have it on the vibe pump but it's really designed to be on a solenoid, so it can show an error on occasion)
- Stainless Mushroom from Chris' Coffee
- Single spout portafilter modified by EspressoParts to bottomless
Barista hustle tamper.
All original parts to return E61 to stock configuration, except for the screw in the port where the thermometer goes - can't seem to find that.
Various Teflon washers for group rebuild
The pressure gauge was warrantied about 6 months ago - the pulses from the vibe pump shake the needle and slowly vibrate the thing to death. This one shakes with the pump pulses, but still works. I wouldn't be surprised if this one gave up before long too.
The cup tray is designed to slide forward so you can fill the tank, but the needle valve is in the way, so I took the guide screw off to allow the cup tray to be lifted off.
The drip tray has many scratches on it, the machine is not cosmetically flawless.
The double spouted portafilter has seen the most use, so the finish is slightly yellowed in comparison to the bottomless, which is hardly used.
The vacuum breaker is a bit finicky, sometimes I have to purge the "false pressure" in the morning because it has been stuck. I suspect it may need replacing before long.
It had issues with thermosyphon stall for a while. I noticed some traces of drips from the fittings on the boiler. I tightened these up and haven't had issues since.
Price is $800. I have the majority of the original packaging, but I really prefer not to ship. Local pickup available in Tulsa, OK. I frequent NW Arkansas and Jefferson City, MO.
Please feel free to contact me with any questions. Thanks!
