Working with "older" coffee beans... - Page 2
And 5 weeks, most of the time, isn't old. For lighter roasts it can be the sweet point but for dark roasts you do see a major drop-off at 3-4 weeks so it also depends on roast level. I've had great coffee that only needed to go 2 clicks finer on my EG-1 and being over 1.5 month old compared to being 3 weeks post roast.
I do agree that updosing, if it's possible, is preferable to grinding a lot finer. If you only need to go a bit finer then that's fine and just normal. But when needing to go way finer then it's better to updose.
This is in no way exhaustive or scientific, rather my personal experience over the last year-ish, with mid-dark to mid-light roasts:mrmoon wrote:How long do beans last in the freezer? is it possible to just keep the coffee in the freezer the whole time and grind as needed? feel like i'm wasting a lot of coffee currently
I buy 24-oz bags of coffee, usually 3-4 weeks post-roast by the time they're in my hands. Bag goes in the freezer and every few days I fill up a small jar on my kitchen counter. Often I'll have 2 different coffees in the freezer so my last shot from a particular batch would have spent at most:
- 4 weeks sealed in transit/storage
- 6 weeks open in my freezer
- 4 days at room temp on my counter
On my Niche, I might start the bag at 20 and finish at 18 or 18.5. I don't think I've ever had to adjust more than 2 unless I've left coffee in the room-temp jar for more than 4 or 5 days, and then it'll jump back up when I fill up from my freezer bag again.
I don't re-bag or vacuum seal the coffee, I just squeeze out the air and use the little metal wire at the top to seal it, it's not even zip-lok style. Basically the laziest approach possible to freezing beans and still getting consistent results with the parameters I've described.
Tangential but I also cut sourdough loaves in half when I get them home - half goes on the counter, the other half in the freezer. Works just like the coffee beans, though it's a pain to get frozen bread to feed nicely into my Niche.
LMWDP #718
