What's the best small brewer + recipes
My favorite brewer is blue bottle dripper but sometimes I want a smaller cup and I've tried a few brewers with no luck. So far I've tried kalita 155 and the origami s brewer.
What I'd like to have is the same quality brew I'm getting out of the blue bottle dripper. What brewer do you recommend and what recipes for it?
LMWDB #691
LeverHeads group on Telegram
- baldheadracing
The (current) Blue Bottle dripper regulates flow rate through a single exit hole at the bottom of the dripper, a.k.a. a Melitta-style dripper. The other drippers that you mention do not regulate the exit flow rate; they rely on you to control the exit flow rate. As you state that you do not have luck with an unrestricted-flow style of dripper, I would suggest an Aeropress using Aesir filters with Tim Wendelboe's method.
Thanks! I don't like Aeropress but I might give it a try. Brewers are easier to clean than Aeropress but you were right about flow restrictions.
LMWDB #691
- yakster
You could try a December Dripper which takes the Kalita 155 filters and has an adjustable flow rate (you can even shut the flow for an immersion start).
-Chris
LMWDP # 272
LMWDP # 272
Good idea! Can you brew smaller ratios with it?
LMWDB #691
have you tried to just use a smaller dose in the blue bottle? you can even use a kalita 155 paper in it. brewers are just things that hold the paper. they stand out from their ripped patterns, shape of the brewer and other things like how the holes are designed. The blue bottle has a single small hole in the middle so a unique profile comes from that perhaps other flat bottom brewers differ with. you can drop any paper in the brewer and if it's "too small" it will brew just as happily. but when you do use smaller doses in order to get a similar extraction you need to grind finer, if you don't the draw downtime will be quicker (because there's less coffee for the water to move through) and this will impact the extraction. A common practice with dosing down is to grind finer to slow the draw downtime but you need to play with it a bit because 3 min drawdown at a larger dose/coarser grind may not taste the same as a 3 min drawdown at a smaller doser/finer grind since a finer grind will extraction quicker so it's trial and error until you find the right taste.Ad-85 wrote:My favorite brewer is blue bottle dripper but sometimes I want a smaller cup and I've tried a few brewers with no luck. So far I've tried kalita 155 and the origami s brewer.
Thanks! I've never thought of that! I will try it with kalita 155 filters and I would say 2:15 total time seems about right for a smaller dose! I'll send blue bottle email asking about it too. Thanks again
LMWDB #691
- yakster
I think I normally dosed the December Dripper with 18 - 20 grams of coffee and a 1:15 ratio. It's been a while, I normally make pots of coffee not cups. How much coffee are you currently using in your filter holder?Ad-85 wrote:Good idea! Can you brew smaller ratios with it?
-Chris
LMWDP # 272
LMWDP # 272
Blue bottle is going to be motivated to keep you focused on their product so just be aware of that with their reply if they discourage it or have specific steps for a lower dose. Obviously the brewer is a specific size for a reason and I'm sure they have a ratio in mind for the brewer but if you find you're not getting what you desire dosing down don't let blue bottle tell you what's best for you.Ad-85 wrote:Thanks! I've never thought of that! I will try it with kalita 155 filters and I would say 2:15 total time seems about right for a smaller dose! I'll send blue bottle email asking about it too. Thanks again
