Water leaks, bubbling in Bialetti Moka
gensiorekk
Postby gensiorekk » Jan 08, 2019, 6:04 pm
There is any solution to fix it, instead of return back to shop?
I also have other problems(bialetti 4tz moka express) - coffee comes out only ~70ml and is very disgusting. No matter if i do it like my italian friend- he pours little warm water-40-60°C, makes a little hill of coffee, and sets fire on little above the lowest gas power. Extraction duration (2min).- one lucky time i get good coffee and a good amount of coffee( ehh i dont know how maybe i need to put perfect weigh of coffee? (2full espresso cups ~2x 70ml) it had a lot of sweet, little bitter and little fine acidity aftertaste.
I try to fill up with 90°C water. Its come more coffee. Maybe(90ml) but always very acidity.
kenyabob
Postby kenyabob » Jan 08, 2019, 7:21 pm
Is this brand new? Does the gasket seem in place and well seated? How fine have you ground it - if you grind coarser, does it still bubble out?
gensiorekk
Postby gensiorekk » Jan 09, 2019, 2:43 am
Its brand new from 5days.I try pre grinded for italian macinato moka from oriental caffe. And some - lavazza-more coarser. Bubbles always comes out, no matter size of grind coffe i put in this.
Intrepid510
Postby Intrepid510 » Jan 10, 2019, 9:27 am
Screw it on tighter. :wink:
gensiorekk
Postby gensiorekk » replying to Intrepid510 » Jan 10, 2019, 10:08 am
Since yesterday, I do not have a problem anymore. Just plainly it stopped bubbling. : D. However, I still can not find the answer to the very sour taste. 50/50 coffee with robusta - which I tried at a friend in a steel bialetti venus was such bitter cocoa. At my place, its acid/, light acid + sweet(not that the worst taste) i. sometimes I burnt this :d.
kenyabob
Postby kenyabob » Jan 10, 2019, 10:16 am
What is your prep and process for making a cup? Are you starting with boiling water?
gensiorekk
Postby gensiorekk » replying to kenyabob » Jan 10, 2019, 10:27 am
I tried hot tap water and medium fire ... Water 90-95 ° and for example, reduce the average power, gradually down, during extraction.
At 90-95 she went out very acidic and she was 2x more than the first way. In the first way, with tap water - the coffee came out less acidic, more burnt
kenyabob
Postby kenyabob » Jan 10, 2019, 8:15 pm
The acid our sourness is usually underextraction. The tip in regular espresso I guess would be to grind finer to increase extraction.
gensiorekk
Postby gensiorekk » replying to kenyabob » Jan 11, 2019, 10:02 am
I think its not underextraction. I use grind little above espresso. My coffe is really stronger than strongest espresso i try., o.o
redbone
Postby redbone » Jan 11, 2019, 10:17 am
gensiorekk wrote:Since yesterday, I do not have a problem anymore. Just plainly it stopped bubbling. : D. However, I still can not find the answer to the very sour taste. 50/50 coffee with robusta - which I tried at a friend in a steel bialetti venus was such bitter cocoa. At my place, its acid/, light acid + sweet(not that the worst taste) i. sometimes I burnt this :d.
Change your coffee to a greater percentage of Arabica vs Robusta and try different water. Since you don't require much water try a lower mineral spring water as a test or mix your current water with spring water.
Semper discens.
Rob
LMWDP #549
