Moccamaster Modification - KBG to KB brewer
- Transparent Roaster
I wanted to do this conversion for a while (KBG741 to KB741 brewer) to accommodate 1-2 cup brewing, but couldn't find if it was possible.
This post confirms it is possible if anyone wants to do the same, by changing the replaceable parts... carafe, bracket, basket. The only problem encountered was that a custom 21mm spacer needs to be designed/3D printed to use the long screws from the KBG. If you can source shorter T20 screws the spacer won't be needed. You can see the spacer in the attached images for reference.
The reverse would also be true, to make a machine a KGB instead of KB, but longer screws would need to be sourced.
CK
