Manual Batch Brewers for 1L+
- SonVolt
I typically use a V60 02 for 500ML or less of coffee. This works great for my personal use but I need something larger for when family and friends are over. I'm trying to avoid buying a drip machine so something manual would be preferred. I'd like to avoid a french press to avoid the extra cleaning steps between batches, would also like to avoid pour-over since I don't want to stand there and do a controlled pour with that much water while guests are waiting. I don't know if this exists, but a Clever style batch brewer would be absolutely fantastic. Dump the water in, set a timer, then drain into a carafe. Does anything like this exist?
What are my options for brewing 1-1.5L of coffee?
Chemex has a 13-cup (handblown) brewer. Stated capacity of 65 ounces, which is 1,923 milliliters; it's a bit pricey. They have a 10-cup non-handblown brewer (much less expensive), capacity of 50 ounces or 1,478 milliliters.SonVolt wrote:What are my options for [manual] brewing 1-1.5L of coffee?
-- Richard
- Almico
Buy a drip machine. That's what they are made for. A 1.5L immersion brew Clever or French Press is not a good solution with company at hand.
- yakster
The larger Chemex brewers use the same cone filter dimensions and angle as the smaller ones and it's hard to keep brew times down to a reasonable time with the increase in bed depth. At this batch size, you're better off looking for a brewer with a flat bottomed basket filter.Richard wrote:Chemex has a 13-cup (handblown) brewer. Stated capacity of 65 ounces, which is 1,923 milliliters; it's a bit pricey. They have a 10-cup non-handblown brewer (much less expensive), capacity of 50 ounces or 1,478 milliliters.
I agree with this, you won't have to wait around and pour during the brew and a drip machine will prevent temperature losses during the brew. If you're dead set against a drip brewer, a double-wall stainless steel press would work, but you have to deal with the cleanup.Almico wrote:Buy a drip machine. That's what they are made for. A 1.5L immersion brew Clever or French Press is not a good solution with company at hand.
-Chris
LMWDP # 272
LMWDP # 272
- SonVolt (original poster)
Thanks everyone. Maybe I'll get an electric drip and store it away when not in use.
- happycat
Almico's suggestion is obviously practical.
That being said, I once took my 1 litre Chemex with a hand grinder and home roast to a party. It became part of the after dinner entertainment and someone even took pictures.
I also see giant moka pots in kitchen stores and wonder if anyone has used them.they are so entertainingly huge.
LMWDP #603
- happycat
Check out Eva Solo. Available in 1 and 1.4 LSonVolt wrote:I typically use a V60 02 for 500ML or less of coffee. This works great for my personal use but I need something larger for when family and friends are over. I'm trying to avoid buying a drip machine so something manual would be preferred. I'd like to avoid a french press to avoid the extra cleaning steps between batches, would also like to avoid pour-over since I don't want to stand there and do a controlled pour with that much water while guests are waiting. I don't know if this exists, but a Clever style batch brewer would be absolutely fantastic. Dump the water in, set a timer, then drain into a carafe. Does anything like this exist?
LMWDP #603
Try a V60 03 size.
“Coffee is always a good idea”
LMWDP #617
LMWDP #617
