Large Pourover/Emersion Brewer Besides Chemex
Hi Folks, I am currently using a 10 cup chemex to make coffee for myself and my wife (paired with my Baratza Vario w steel burrs for grinding). I have been making large pourovers (750-850 ml of water) as we drink like 4 cups of coffee between the two of us.
I wanted to see, are there any large pourover/emersion brewers that people like besides chemex? I have been getting decent results with the chemex but want to see if there is something else that people like better, or just something else to play with.
I've got the size 03 plastic v60 for larger brews (around 850ml) and I prefer it to the Chemex personally. I like that I can grind finer with the v60 filters and I've always run into "suction" issues (filter creating vacuum type effect with side walls) with the Chemex. I follow James Hoffman's most recent v60 method he released on his YouTube channel.
Ok good stuff, I'll look at the size 03 V60.
What about something like a kalita wave or other flat bottom brewer? Can anyone comment on what is the largest amount that can be brewed in these effectively?
Bonmac would be another one that is flat-bottomed with a hole(s) but I couldnt think of the name
- baldheadracing
On the immersion side, I use a large Espro press. Serves as a great serving vessel as well. Using a standard flat-bed paper filter between the Espro's two stages of filtration gives a very clear cup.
- Supporter ★
Another method to consider: Eva Solo makes a 1.7-liter carafe.
"It's not anecdotal evidence, it's artisanal data." -Matt Yglesias
https://www.amazon.com/BUNN-Brew-Funnel ... B00DBOPOU8
for larger batches (60:1000, 72.5:1250 etc), I will use the above flat bottom with the matching bunn filters or the plastic hario v60-03. given that doses greater than 25g are not optimal within the v60 geometry, I will mitigate the need to grind coarser by keeping the grind about the same fineness but decrease agitation by using the gabi master b.
Ah, I hadn't thought of the paper filter idea with my Espro to solve the slightly muddy cup. Thanks for that idea!baldheadracing wrote:On the immersion side, I use a large Espro press. Serves as a great serving vessel as well. Using a standard flat-bed paper filter between the Espro's two stages of filtration gives a very clear cup.
So the Gabi Master B helps reduce drawdown time? Do you use one long pour for a 1 L brew or several pours? How long does it take to pour all of your water?njw wrote:https://www.amazon.com/BUNN-Brew-Funnel ... B00DBOPOU8
There's also the Sowden Softbrew (which does both hot and cold brew) and the Eva Solo (which I'd be happy to sell to you since I never use mine).
