Heat Retention, Clever vs Bonavita Immersion
I switched from the Clever to the Bonavita under the assumption that porcelain would hold heat better than plastic. I never bothered testing. Then I saw this video by Scott Rao wherein he recommends the plastic V60 over the ceramic and metal ones.
http://www.youtube.com/watch?v=c0Qe_ASxfNM
He claims that the plastic V60 holds heat best and recommends proving it to yourself by touching the sides. So I tried that with the Clever and the Bonavita. To my surprise the Bonavita was a lot hotter to the touch, implying it was seeping heat out more quickly than the Clever.
I did a test with a cooking thermometer. I performed the following with each brewer. From a variable temperature kettle I used 200° water to preheat the brewer. I emptied the brewer and then filled it again with 200° water. I immediately inserted the thermometer. I noted the temperature at 1, 2, 3, and 4 minutes. Here are my results.
Clever
1 minute - 190°
2 minutes - 183°
3 minutes - 178°
4 minutes - 175°
Bonavita
1 minute - 186°
2 minutes - 181°
3 minutes - 175°
4 minutes - 169°
Since I had already performed the touch test I wasn't surprised that the Bonavita lost heat faster. But I was surprised at how quickly heat was lost in both cases, and especially in the first minute, even though the surfaces were preheated. Also, this test was performed without coffee, and maybe I ought to perform that test also. I would think the temperature would drop even faster in the first few seconds as heat is transfered to the coffee as well as to the surfaces.
At any rate I've now switched back to the Clever, but I'm thinking of looking for a clean (no sludge) immersion brew method that retains heat better than either of these. Perhaps an insulated French press with a paper filter?
Clever
1 minute - 190°
2 minutes - 183°
3 minutes - 178°
4 minutes - 175°
Bonavita
1 minute - 186°
2 minutes - 181°
3 minutes - 175°
4 minutes - 169°
Good idea. I actually have a Yama stove top, but I've never tested the slurry temperature. I'm guessing it would stay pretty hot with the hot air bubbling through. Another experiment!
- EddyQ
Did you use the lid? The best insulation is air and if it is free to move it will take heat with it. And since the hot water also is evaporating and taking heat with it, there is likely a lot more cooling when left open.mikemaddux wrote:I did a test with a cooking thermometer. I performed the following with each brewer. From a variable temperature kettle I used 200° water to preheat the brewer. I emptied the brewer and then filled it again with 200° water. I immediately inserted the thermometer. I noted the temperature at 1, 2, 3, and 4 minutes. Here are my results.
Plastic and porcelain conductivity is quite different, but comparing conductivity to the air around the outer surface, the air is the real insulator. And with slight movements of air, you may get different results.
The porcelain likely has a lot more thermal mass. Once heated, it likely won't change temps with the same flow of heat. But did your pre-heat have enough heat to bring it to 200F? With plastic, perhaps it hit equilibrium temp at higher temps?
Thanks for the data. I only have the Bonavita and am also curious which would do best.
LMWDP #671
- redbone
I have both units. Clever maintained heat better only if the Bonavita was not preheated otherwise the Bonavita porcelain is more heat stable.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
My results were different, but it was only one test.
Check this out. At the onset Scott says plastic is better cuz u don't feel heat when u touch it. Makes sense to me.
That's what got me started (see my original post). I performed the touch test and the Bonavita was much hotter.Bob_M wrote:Check this out. At the onset Scott says plastic is better cuz u don't feel heat when u touch it. Makes sense to me.
- redbone
Beyond heat retention it's all about what it tastes like in the cup. Same taste after many evaluations. Considering similar taste and similar process of using both I prefer the Bonavita at home for its non staining surface and ease of cleaning. The CCD has a place at work as it more portable and less susceptible to breakage. Can't go wrong with either based on taste. The choice is more of a preference vs performance.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Robert I have both also. Bonavita preheated used at home. Clever for travel.
