Espresso brew temperature experimentation
I recently realized realized I rarely dial in using temp, hence ever touch temp at all...
I'd like to hear about other's approach to espresso brewing temp when dialing in espresso:
- where do you start?
- based on what?
- is temp the first parameter you are moving?
- is it the last?
Thanks
- based on what?
- is it the last?
Thanks
- mkane
We use a Rocket & the recommendation is just off boil.
For me, temperature is one of the first things I change when dialing in. I generally look to the roaster for recommendations as a starting point, then adjust to taste. I usually end up within 1 degree of the recommendation based on my Scace device calibrated machine. From my experience, the proper temperature is critical to a good extraction. If you don't have a starting temp recommendation from the roaster, generally darker roasts will need lower brew temps and lighter roasts will need higher brew temps.
Timely thread, I just upgraded to a Vetrano 2B EVO and now have more precise control over temp vs my old Anita with HX temp surfing. I also try to use the roaster's recommendation as a starting point, but many don't even provide the recommendation. I have been using 201 which is my typical roaster's (Klatch) recommendation, and then usually dialing down to 200 or 199 based on flavor. I would be interested in others' advice on how to best dial in a bean if the roaster doesn't provide guidance.
I think broadly speaking temps can be adjusted based on the roast profile as some of the first things to do to dial in a new coffee. Higher temps for light roasts and lower temps for darker roasts. Definitely if you're having a hard time dialing in or its always sour temp, etc the temp might be a good micro adjustment to give you the right balance.Idfixe wrote:I recently realized realized I rarely dial in using temp, hence ever touch temp at all...
- based on what?
- is it the last?
Thanks
And what is your "range" of temp used?mike01 wrote:For me, temperature is one of the first things I change when dialing in. I generally look to the roaster for recommendations as a starting point, then adjust to taste. I usually end up within 1 degree of the recommendation based on my Scace device calibrated machine. From my experience, the proper temperature is critical to a good extraction. If you don't have a starting temp recommendation from the roaster, generally darker roasts will need lower brew temps and lighter roasts will need higher brew temps.
I rarely see temp on espresso from the roasters I buy from.SWR wrote:Timely thread, I just upgraded to a Vetrano 2B EVO and now have more precise control over temp vs my old Anita with HX temp surfing. I also try to use the roaster's recommendation as a starting point, but many don't even provide the recommendation. I have been using 201 which is my typical roaster's (Klatch) recommendation, and then usually dialing down to 200 or 199 based on flavor. I would be interested in others' advice on how to best dial in a bean if the roaster doesn't provide guidance.
I've heard also adjustinf temp based on expected flavors:
- floral = low temp
- chocolates = med temp
- fruits = high temps
Most of the coffees I use would be considered medium roast, but some are lighter or darker than others. I'm almost always between 198-202F, with 200F being most common. That sounds like a pretty small range, but even a 1 degree change is noticeable to me and I feel like my taste buds aren't even that great.Idfixe wrote:And what is your "range" of temp used?
- cerone
I usually start at 200, then dial everything else in, then go back and tweak temp if I can't get it tasting right by adjusting grind/ shot time.
