Brewing methods similar in taste to Chemex
I have been using both a V60 and a Chemex for pour over brewing for months now. I use the Chemex (6 cup) exclusively at work where I can share the coffee with other coffee lovers. I find I enjoy the taste of the Chemex more than that of the V60. I was wondering if there are any pour over devices that produce similar taste profiles as Chemex does? The reason I ask is that making coffee for one person in a 6 cup chemex never turns out very well, and I also hate the look of the 3 cup chemex. Thank you!
- MB
I had the same issue. I just make a 500ml batch and put half in one of those vacuum insulated stainless steel water bottles that I have preheated. Several hours later it's still piping hot. If you are a truly one cup and done drinker, then this won't help of course.
LMWDP #472
Try a Chemex filter in a V60. It works, and if the excess on top bothers you, you could cut it off.
The C70 ...maybe the Chemex FP-2 Filters for 3 Cup can be used in the dripper...
https://stanthonyind.com/products/c70-ceramics-brewer
Thank you guys, this is all great advice. I'll try these tips out!
- mkane
Cafec filters are the bomb; https://cafecusa.com/pages/paper-filters
Would you be able to expand on what makes cafec filters "the bomb"
- mkane
- TomC
I bought some the other day after seeing they also had the filters that Tim Wendelboe is promoting and I was hellbent on buying some of those anyway.
I got the three different roast level filters and 4 packs of the trapezoidal ones that I hope will fit well enough in my Technivorm at work.
If you use a v60 filter paper thick enough, they would have similar taste to chemex.
There is Kinto cotton filters, cafec light roast filter and mola(never tried but I heard they are thicker than Hario).
