Bell Syphon Coffee - Page 4
- yakster
I still have a bunch of coffee toys at work, someday I need to go in and box them up since I'm working from home now. Where to put them? What one size would you recommend?
-Chris
LMWDP # 272
LMWDP # 272
- baldheadracing
Actually, that's the second reason this device is now in my not-used-coffee-devices-drawer (closet if I include no-longer-used espresso machines ). This device brews a fixed volume of water; no more, and no less. That's fine if the brewer's only capacity is what one wants, but I found that I just don't make one cup of coffee that way. When I make a single cup, I decide how big a cup to make when I am weighing out the beans. OTOH, if one always makes the same size cup and that size matches the brewer ...
Craig , not sure if you are using this correctly. You can add any amount of water to brew. Once you cross that minimum threshold, Syphon will kick in and dump out all the water in the device ...I even brew 20oz at a time. No issues....
Correct. Once the siphon starts running, you have from then until the siphon begins to suck air to add any amount of water you like. I do this all the time.You can add any amount of water to brew. Once you cross that minimum threshold, Syphon will kick in and dump out all the water in the device ...I even brew 20oz at a time. No issues....
- baldheadracing
I'm not using it correctly - I'm not using it at all!DanN wrote:Craig , not sure if you are using this correctly. ....
(I found myself more comfortable with other brewers. YMMV.)
