Behmor Connected Brewer change defaults?
Unless I am missing something.. I can't see where I can change the default settings for brew temp and pre-soak.
I bought a new Behmor brewer just because my old Behmor was getting kind of old.
Vince
Vince
- sweaner
I assume that you do that with the app?
Scott
LMWDP #248
LMWDP #248
As far as I can see you can make favorite brew settings but can not change the default brew. As far as I can see...
Vince
Vince
- pizzaman383
- Supporter ❤
Use the "set quickstart" feature of the app.
Curtis
LMWDP #551
LMWDP #551
Just confirmed with Behmor. You can not change the defaults at this time.
I really don't see the point of this product.
I got it because my old Behmor was getting old and changing the brew settings would be easier.
I will get the 2.0 instead.
I'm assuming you are wanting to change the settings from default for the quick start button. It can be done through the app. Here is a link explaining the process.
https://behmor.com/knowledge-base/how-t ... ick-start/
You can make a custom start using the app but you can' t change the defaults. So I would have to brew with my smart phone every morning.
I didn't realize it defaults back. That is dumb, You would think they could change that with a software update. You could leave a old device phone/tablet just for the connected like the DE1. I'm pretty sure they have stopped making the connected, I think for the new model, the Brazen Plus 2 they went back to the onboard buttons. I have enjoyed using the connected, but it has its own quirks. It connects via WiFi not Bluetooth & needs to be 2.4Ghz secured connection. I like the idea the brew tempature is adjustable, but that also creates other issues. The connected takes twice as long to make a pot of coffee because it heats all the water to temp before even starting to brew.
- yakster
This is how the original BraZen and BraZen+ works. I fill using the hot water tap from my water dispenser to short-cut this. Does the BraZen 2 work differently?nlukas wrote:The connected takes twice as long to make a pot of coffee because it heats all the water to temp before even starting to brew.
-Chris
LMWDP # 272
LMWDP # 272
