Mypressi TWIST - Second Look - Page 2
- HB
- Admin
This concludes the formal evaluation of the mypressi TWIST. Questions and comments from the HB membership are welcome!
Note: For those that are interested, the thread Mypressi Twist covers the TWIST's introduction in April 2009 thorough early comments from SCAA conference attendees, some informal reviewers, and clarifications from the product's designer, Stephen O'Brien. The thread Let's do the mypressi TWIST is dedicated to comments from early owners. Contributors to this thread may wish to read these other threads to avoid repeating earlier discussions.
- Peppersass
Thanks for your efforts, gentlemen.
Looks like the Mypressi does a nice job running very hot water through coffee ground with a superior grinder. Thus, it could be a great choice for an office or vacation cabin setting, say paired with a Baratza Vario and any number of inexpensive water boilers. Around $600 for the solution isn't too bad for the truly committed.
But what about the travel scenario? How is the espresso when ground with something you can easily throw into the suitcase, like a Kyocera hand grinder, and using water heated in the typical hotel room coffee maker? I realize such an investigation would likely have more to say about the quality of the grinder and hot water source, but it would also be a service to those contemplating the Mypressi for travel.
Perhaps someone will come up with a chic travel case for a Mypressi, a Baratza Vario and a small water boiler.
I'd like to try one with a Baratza Maestro. A Vario is quit a bit out of range for many folks for a secondary setup. A refurbished Maestro is $68.
- michaelbenis
Many thanks to everyone. That's brilliant. Looks like this may well be the best choice for my camping trips and motorcycle rallies and forays into the wilderness that is British hotels. By the sounds of it superior to the Handpresso and Aeropress.
Cheers
Mike
Cheers
Mike
LMWDP No. 237
- HB
- Admin
Having tried it for French press, I would not recommend coffee makers in typical hotel rooms for heating water. A cheap and travel-friendly solution is an immersion heater. They sell for $5 to $10 and are meant for heating one cup, which is perfectly sized for the mypressi.Peppersass wrote:But what about the travel scenario? How is the espresso when ground with something you can easily throw into the suitcase, like a Kyocera hand grinder, and using water heated in the typical hotel room coffee maker?
We didn't test a manual grinder, but I will try to borrow one and report back.
- AndyS
Lately there has been a rash of posts questioning people's experimental techniques, so I apologize in advance for adding to the cacophony....HB wrote:This session featured another round of blind taste tests, this time with a single origin espresso under development. The result? Surprisingly, against the resident La Marzocco FB-80, the diminutive TWIST won every round with three blind taste testers. We really liked this SO... a huge fruit bomb. Think blueberry pancakes with light maple syrup. To get similar pour speeds from the two machines, we dosed the LM at 19 grams and the TWIST at 22 (!!) grams and pulled 1+ ounce ristrettos.
But...comparing 19g doses on one device to 22g doses on the other?
Maybe 22g is simply what the coffee "needed?"
-AndyS
VST refractometer/filter basket beta tester, no financial interest in the company
- HB
- Admin
Sorry, I cannot say because we didn't bother dialing in two grinders to achieve the same dose. We agreed that the difference between the rounds was no larger than the variance we'd expect shot-to-shot on the La Marzocco. In other words, when pulling ristrettos, the appearance, flavor profile, and texture of the TWIST and La Marzocco espressos were nearly indistinguishable.AndyS wrote:Maybe 22g is simply what the coffee "needed?"
- mhoy
Coupled with a hand grinder, this is likely the best thing out there for a bang vs buck scenario.HB wrote:In other words, when pulling ristrettos, the appearance, flavor profile, and texture of the TWIST and La Marzocco espressos were nearly indistinguishable.
Mark
Hello, I was wondering how many doubles you were pulling with each cartridge? The Mypressi website says about 4 doubles per cartridge. Can you confirm this? Could you tell when they cartridges were running low, ie. the first 3 shots pulled at 9 bars but the 4th or 5th started to sputter?
It is 4 double shots. I wouldn't recommend trying to pull a 5th, it is likely to die mid-shot. The lack of "remaining shots" indicator is an issue as I mentioned in the review. I used to pull the trigger without the water chamber on, to see how strong the air is coming out. At the end of the cartridge, it does taper off and I suspect pressure profile goes down.
Abe Carmeli
