La Marzocco Linea Micra Espresso Machine Review
- HB
- Admin
La Marzocco is best known for their commercial espresso equipment, but since the introduction of the home-friendly GS/3, they've had a special place in the hearts and minds of this site's members. Built on the feedback from owners of the GS/3, they later introduced the La Marzocco Linea Mini. Like the GS/3, the Linea Mini has its fans who actively participate in the forums.
We would like to think that forum members have indirectly helped influence the design of the next iteration of La Marzocco's home lineup, the Linea Micra:
Photo courtesy of La Marzocco Home
In the video below, Martin Keen and I give a quick introduction and first impressions. In the next video of this series, Martin and I will compare and contrast it with a popular E61 double boiler espresso machine, the ECM Synchronika.
As the name "Micra" suggests, it's really, really small. While it's easy to focus on its obviously reduced size compared to the Linea Mini, the Micra isn't just a scaled down version of its bigger cousin. Under the hood are some genuine innovations.
Topping the list of surprises is a rapid cold to ready-to-brew in barely 5 minutes, thanks to its integrated brew boiler/group combination and unique portafilter. It also sports a powerful steam boiler and a whisper-quiet rotary pump. Like the Mini, the Micra can run from a water reservoir that's refilled by removing the driptray or it can be plumbed-in.
Several reviewers have had evaluation units to test the last few weeks and they'll post their initial review comments today. Their experience reports will include group taste tests. Once they've finalized their writeup, their loaner La Marzocco Linea Micra will continue to the next reviewer. Stay tuned!
Please note: So the reviews can be posted in an orderly fashion, this thread will remain closed. If you have questions about the review, please post them here.
- another_jim
The La Marzocco Linea Micra - HB Team Review: Jim Schulman's segment
Headline: The Linea Micra is a compact, apartment friendly version of the Linea Mini, with an improved, integrated brew boiler-group combination, a smaller 1.7 liter steam boiler, and a rotary pump. Like the Mini, it can run on a tank or be plumbed. It measures roughly 12 inches wide, 13 inches high, and 17 inches deep. It will be priced under $4K.
Back Story: About three weeks ago a very large preproduction crate with a very small machine inside arrived at my home.
It was the beginning of a team review of LM's new Linea Micra, a smaller version of the Linea Mini. The machine I tested for the last three weeks is now with Dominick. Dan, Tom, and Ryan also have machines that they will test and pass along. Scott Gugliemo is to thank for this early look. The HB reviewers agreed to maintain confidentiality prior to the product announcement; but we are not constrained in any way about what we say in our reviews.
Some specs and details: These are my own quick measures; later reviewers will be diving far deeper and more accurately into the details.
First off: this is NOT a flow profiling machine. The paddle is a simple on/off switch, like the stock LMLM's. The Micra's sizing and internal layout differs from the LMLM, so I cannot say whether the existing flow control kits will work.
Dimensions in inches:
-- Width 11 1/4
-- Height 13
-- Depth
---- Rear to Front feet 13 1/2
---- Rear to drip tray end 16 1/2
---- Rear to PF Handle: 21
Power Use and Start Times:
-- 1600 watts max
-- From cold start to brew ready: 5 minutes
-- From cold start to 2.25 bar steam: 6:45 minutes
-- Idling power use after warmup estimated at 89 watts
Steam Pressure:
-- 2.25 bar, froths 4 to 6 ounces in under 10 seconds. More details by later reviewers.
Shot Temperature Stability:
-- Straight line profile with less than 1C change. More details by later reviewers
Supplied Extras
-- Bottomless PF with single and double spout plastic inserts
-- 14 and 17 gram baskets
-- Convex Steel tamper with 58mm and 41mm ends
-- Frothing jug suitable for 6 ounce cappas
Using the machine and who should buy it: The machine is small, but has the solidity of a commercial machine. There are now many high quality, dual boiler, rotary pump home machines running from $2.5k to $3.5k; the Micra is smaller than these and also more solid. This is not a matter of one thing that stands out, but of all the details being a little bit more solid and well finished. I do not know if this improved fit and finish will translate into higher reliability; but it does, IMO, justify the price premium.
The overwhelming impression in using it is an understated competence. This is a hallmark of both the standard and Mini Linea (see Chris Tacy's review); but the Micra's group has better stability and shot tuning. The sweet spot for dose and grind is wider than the other Lineas, and the shots will reflect the coffees faithfully, without taste distortions or exagerations, after only minimal dialling in. I did not miss the flow profiling capabilities of the Bianca except for extremely light roasted or unbalanced coffees.
We have a regular get together with local HBers, and this time around, Dominick remarked that it was the first time the bulk of the talk was about the coffees rather than the machines or grinders. People would say they wanted to try one of the many coffees available -- they'd prep and grind, then mostly use the Micra to make the shot, rather than the Bianca or Decent, since the whole process was so fuss free. Note that most of the attendees own lever or profiling machines, so this was not a matter of know how.
Lever and flow profiling machines are like musical instruments, great for playing all the variations on a single coffee. The Decent is about deeply exploring all the variables of espresso prep. The Micra is more like a perfectly transparent tool, so that the emphasis is on the coffee, not the process. The Linea Mini has become well loved by roasters for their cupping labs and coffee sales demos, since it is bullet proof, understated, and puts the spotlight on their coffees. The Micra is solidly in this tradition; but aimed for home use. Think of it as a machine for "cupping" lots of espressos with minimal fuss.
In terms of capacity, like the Mini, it can turn out straight shots at one a minute indefintely. Unlike the Mini, it will hit limits steaming cappas after about four, and need to recover for a few minutes. So it is not suitable for catering gigs; but it will handle most in-home gatherings. In this respect, it is like the other dual boiler machines in this class.
Who should buy it? If space is a constraint and cost isn't; this may the best machine out there. If you like to try lots of different coffees, and get a faithful impression of each without endless fine tuning; this is a very good choice. If you want to do extremely light roasts, or examine all the variations of a single coffee; this is not your machine. Profiling machines do that better.
You will need to know your way around an espresso machine to get the most out of this machine. But it is forgiving enough to make learning to do so a pleasant experience; so this is is also a good choice for a beginner willing to learn.
A few details
-- Will you miss flow control?
I did two rounds of blind taste testing pitting the LMLu's shots (our abbreviation for the Micra) against my Bianca's profiled ones. This involved pulling the shots simultaneously, then me shuffling the cups, while my tasting partner looked away, then vice versa, then tasting and comparing notes. In the first round, we used one week old medium to light roasts, and we found no systematic differences. In the second round, we used 3 day old light to very light roasts, and the profiled shots were systematically distinguishable in being softer. This benefitted the more edgy coffees and hurt the mellow ones.
-- Maintenance
Others will comment in more detail. The group and brew boiler can be uncovered undoing four screws. The rest of the machine requires, in addition, loosening two nuts, removing the top warming plate, then undoing several screws to lift off the case. The pump pressure can be adjusted with only the warming plate removed, but firmware replacements seem to require a full opening up. Overall, the servicing of this machine is about the same as the LMLM
-- The App
This is my biggest beef. The shot temperature can only be adjusted via the app. Despite the machine having bluetooth (it's used to connect it to your home WiFi), you have to establish an account and log in to LM Home to adjust the machine. First off, this is a ridiculous invasion of privacy. Second it is buggy. I got locked out after a bug caused it not to recognize my password nor allow me to reset it. The machine should be adjustable locally via bluetooth, and not require logging into the LM servers. Everything about the Linea is understated and no fuss, except for this absurdity.
Please stay tuned for the rest of the team; this is just the first round.
-- Width 11 1/4
-- Height 13
-- Depth
-- 1600 watts max
Steam Pressure:
Supplied Extras
A few details
-- Maintenance
-- The App
Jim Schulman
- another_jim
Jaroslav wrote:For anyone interested to see the internals in detail, here's the Parts Catalogue which includes all specifications (weight, individual boiler wattage, etc.).
Jim Schulman
- IamOiman
I had to give the Linea Micra some thought before making a conclusion due to my complete and singular familiarity with lever machines only. This is a machine that is completely new for me outside of a few times while in Italy where I tried pump machines in a commercial environment. Until I received the Micra last month I had never used a pump machine at home.
Unboxing and First Setup
When I received the machine I was surprised at how small it was. I had my Faema Urania in the kitchen when the Linea Micra arrived for a size comparison. I was easily able to move it myself from the garage up three steps and into the house. Perhaps if a user is uncomfortable with moving it alone a second hand will make the job a breeze. It's 44lbs empty according to official specs, which is very light among the many lever machines I own (just the domestic machines weigh less). The feet have suction cups to secure the Micra to the counter surface more easily.
The matte finish is nice and goes well with the stainless steel backsplash. I only utilized the reservoir tank and deep drain tray (ie I did not make any water connections, neither inlet nor drain) for this test. Setup was pretty simple. The drain tray just slips off the front and the reservoir tank can slide out for easier access of the cap for filling. I have since afterwards left the tank in place after taking off the drip tray and can fill it without moving it. The plug is a standard NEMA 5-15 configuration, or a typical 120V 15A plug. Turning on the machine will fill both the brew and steam boilers, and as others have made note the Micra is ready for brewing in 5 minutes and steaming in under 8 minutes. If you want your cups warmed up I would recommend 20 minutes minimum.
I pulled maybe 20 shots on the Micra before beginning the real comparison with my lever machines, although I was already making conclusions since I often had the Micra and at least one other machine on concurrently. To make the comparison interesting I decided to have the Micra compete with the original lever (and modern espresso) machine, my 1 group 1953 Gaggia Classica. I also have a 1 group 1957 Faema Marte in the kitchen for further comparison. There was no true proclivity towards the two levers I selected, they just happened to be what I was using at the time of this review (the Classica is my main driver right now since it has the timer and water fill line attached to my FloJet). I often switch out what machines I use throughout the year.
Comparing to the Lever Machines
I will make a caveat stating that among the many lever machines I own (and of which I have pulled espresso on the majority of them) that I can produce just about the same shot results with my preferred coffee, the five Saka Caffè Bar Line roasts. The comparison between the Marte and Classica will be less interesting than the comparison between the Linea Micra against the Marte and Classica.
To make the comparison fair I used the same coffee in this test, Saka Caffè Espresso Bar. This is a 50% Robusta 50% Arabica roast that makes a very nice espresso that I try to describe as 'vanilla' and 'chocolate' depending on how I extract it. The dose is the same for all three machines but the Micra will use its 15g basket that was included with the machine while the Classica and Marte will use the same style 14g basket that originally was sourced from my Bosco Sorrento. The dose is 14.5g of coffee, and all three doses will be grounded on my Malwani Livi.
I did not change the temperature setting of the Micra, which came to me set to 94° Celsius/201° Fahrenheit. It can be altered on the Marzocco Home app along with automatic turn on/turn off, idle times, and steam boiler pressure.
I pulled quite a few shots between the three machines, and in the following pics I pulled all three shots about the same time. This was just a sample of all the shots I pulled, approaching a number that even makes me jittery. The Micra stands out because its body is very comparable to the levers, and in fact there was a ton of deflation from the Micra shot (part of it is due to the Saka roast being less than 2 weeks post roast date and is still degassing just a bit). I did not expect this result in testing.
Just to iterate: The Saka Cup is from the Classica, the Coffee Point Cup is from the Micra, and the Caffe Toraldo Cup is from the Marte.
In terms of taste I can dial the three machines to produce just about same result, but some adjustment is required as they all have slight preference in grind size. This is why the Micra shot was pulled a little quick in the photos but other times it worked out much better. I had a tester with me to ensure my conclusions were accurate with no prior info on which cup was pulled from each machine. In the end the tester stated it was hard to discern which machine each shot was pulled from but the preference was towards the Classica followed by a tie with the Micra and Marte. The Gaggia Lever group is quite the formidable opponent but it is a pain to service/maintain.
Frothing was extremely easy, I had no issues at all with the steam wand. I also will note I only used the double spout for splitting shots when sharing espresso and did not really use the single spout. They work fine and I understand people may be thrown off by the plastic, but I did not notice any strange or 'off' taste compared to bottomless.
Maintenance
Serviceability is pretty good too from an access perspective. Accessing the group is easy by undoing four slotted machine screws on the top of the front block. La Marzocco managed to cram a lot of parts in a small footprint. The back part of the cup tray is held in by two very strong magnets, and a strong tug is necessary get it off. Two M4 nuts secure the front part of the grille and also need to be loosened for the grille to fully detach.
The body panel slides off by undoing the four upper slotted screws and a phillips screw in the back holding the control box housing, revealing quite a few parts inside that surprised me to be honest. I'm impressed at the density of components. I had a Marzocco tech with me during this time and he told me he likes the Micra layout far more than the Linea Mini due to the ease of accessing the control box and the way that is mounted. On the Linea, he told me there are parts dangling once the housing is off and can be awkward to access.
The lower four slotted screws simply secure the two manometers to a bracket (two screws each).
The App
My final quip is the home app necessary to program the group temperature and a few other items. I absolutely am in the camp that prefers on-hand tinkering. I dislike utilizing the app primarily due to privacy concerns and the fact I never needed an app to program my levers (albeit I had nothing fancier than a Sirai pstat to adjust). I realize that having the options to change settings on the machine itself may have resulted in a screen or board that interrupts the looks, but perhaps if it was hidden somewhere out of side would have been the solution. I bet Marzocco looked into that already but I am stating my opinion only.
Conclusions
I went into this espresso machine thinking I would not be impressed, but now I will state the opposite. It is a nice machine that definitely competes with levers. I cannot say anything in regards to flow valves, mods, or anything pump specific that may be present on other pump machines but not lever machines. I also do not have a good understanding of the price point of $3900, but from using and inspecting the Linea Micra, I do not believe the price is too high from a component quality standpoint.
Maintenance
The App
Conclusions
-Ryan
LMWDP #612
LMWDP #612
- cannonfodder
La Marzocco's Linea Micra is a welcome addition to their existing product lineup. It puts them solidly in the home market with one of the smallest double-boiler rotary pump machines. Compact in design but innovative in features, technology, and construction.
The Linea Micra takes many of its styling cues from its two larger namesakes, the Linea Mini and Classic. This is not simply a miniaturized version of its siblings. They packaged a lot of technology, engineering, and swagger into a 12" x 12" x 15" footprint. Its reduced footprint makes it ideal for small spaces leaving lots of working room on a standard kitchen countertop. When deciding where to locate the machine, keep in mind the steam wand is on the right side so you may want a little working room on that side of the machine.
Out of the box, the Micra took me 15 minutes to set up. The Micra is a smart device with both Bluetooth and Wi-Fi. You will want to download the La Marzocco Home app on your smart device and create your account in advance to speed up the process. If you already have a La Marzocco device, then the Micra can simply be added to your existing app/account.
The app provides a tutorial on how to put the machine in Bluetooth discovery mode. It is a simple process. You turn off the main power, move the brew paddle to the on position, turn on the power then move the brew paddle back to the off position. The pump will not run so do not worry about water dispensing.
Once the machine is discovered and paired via Bluetooth, you will be prompted to attach it to your Wi-Fi network. Once on your network, you can remotely change settings, the machine turned on/off, firmware updated (when needed), and support logs for remote assistance sent via the La Marzocco cloud. If you have concerns about an IoT device (Internet of Things) on your home network, you can use Bluetooth for close proximity control. The Micra has no on-machine control interface. You will need a device (cell phone or tablet) to control the machine and work its advanced functions.
The home screen is relatively clean.
Status gives you the current status of the machine. Power, steam boiler on/off, and backflush can be controlled from here. You also have a temperature summary.
Settings are where you will do most of your work.
Your temperatures are set from the 'Temperature' option, big surprise there. The brew boiler is adjustable in 0.1 increments. The steam boiler is limited to 3 presets: Low (1), Normal (2), and High (3).
If you plumb in the machine, your pre-infusion is enabled and configured in the 'PRE-BREWING & PRE-INFUSION' menu. If you plumb in the machine, first enable the 'ENABLE PLUMB-IN' which unlocks the 'ENABLE PRE-INFUSION' option. Once that is enabled the 'DOSE 1', which is an odd way of labeling the setting, will become available. From there you can set the pump delay from 0.0 to 24.0 seconds. A note on this setting. It is labeled as 'PRE-INFUSION OFF'. The pump on delay is that time minus one second. A setting of 8 gives you 7 seconds of mains pressure, on second 8 pre-infusion turns off and the pump starts. For some reason that confused me the first couple of times I pulled a shot.
The Auto On/Off menu allows you to set a daily on/off timer. That way the machine is on and ready for you in the morning and powers off in the evening when you are finished for the day. I have it set for a 7am power on and 6pm power off. You can change the on/off time based on the day of the week.
The AUTO STAND-BY setting lets you define a sleep timer ranging from 0, which is disabled, to 240 minutes in 10-minute increments. That will power down the boilers after a given period of inactivity. If you want the machine to turn on, simply walk up to the machine and flip the brew paddle on and then off. It will automatically come out of standby and heat up for use.
Another interesting note, the app is also a shot timer. With the app open, when you start a shot the screen changes to a shot timer. Handy feature since the Micra has no integrated chronograph for shot time.
The Micra has an optional plumb-in kit. I was provided with a pre-production kit so I can review the mains pressure preinfusion function. I am not going into detail on the kit, what I have is a bespoke kit for function testing. I will say it is a simple process to retrofit and took me one-half hour to install. If you plumb in and drain out the machine you will be required to remove the top front cover, cup warmer, cup warmer supports, and machine shell to reach the internals. The machine is pre-configured by La Marzocco for operation from the static tank. You will need to re-adjust the brewing pressure to compensate for the increased input pressure. You will also need a good pressure regulator since output pressure is directly affected by input pressure. The pump is a bit of a pain to adjust. You will need a very long and thin flathead screwdriver to reach down around internal components to the bypass valve adjustment. Thankfully once it is set, you will probably never change it again.
The overall construction is good with minimal use of plastics. The internal space of the machine is well-used. In the IT world, I would call it a high-density rack. There is a lot of stuff packed into a very small space.
The brew boiler is part of the brew group. The steam boiler is vertically mounted and insulated, both are stainless steel. The rotary pump is neatly tucked away in the bottom rear of the machine with dampening bushings to reduce vibration. The brain box is mounted high in the rear of the frame. It is mounted to a polymer assembly or shield that provides physical separation and insulation from the hot boiler. The top of the assembly is also covered. This will provide a barrier against water dripping onto the electronics from the cup warmer. The steam boiler emergency overpressure valve and vacuum breaker are drained to the drip tray to prevent damage to the internals and electronics in the event of a failure. The electrical wiring is also covered in silicone shielding
The brew paddle and steam/water controls are smaller than those on the Lina Mini or GS3. They are size-appropriate to the reduced footprint of the machine.
The water tap is short to allow maximum clearance between it and the drip tray. I measure it at 4.5 inches. The stubby spigot is equipped with an aerator but the assembly is fixed in place.
The steam wand is mounted on a ball valve giving you full movement. It is a relatively stubby wand but again it is size-appropriate to the Micra. It just clears the drip tray and allows you to purge the wand into the drip tray before use. The wand is equipped with a 4-hole tip. Measuring the wand, you have a 3-inch drop between the bend and the steam tip. I have had no issues with steaming. You do need to use a size-appropriate pitcher. If you try steaming 4oz of milk in a deep 20oz pitcher then yes, the wand will not reach. Using the supplied 12oz stainless pitcher I have steamed 4 to 8oz of milk with no issue. For more than 8oz you may want a larger pitcher as the vortex created by the wand, combined with the volume increase when frothing could swirl the milk out of the pitcher.
An interesting note about the steam wand. It is a no-burn wand but lacks the silicone liner used on most no-burn steam wands. This unit is all stainless steel, double-walled, vacuum-sealed, and welded. It is manufactured for La Marzocco by an aerospace company that produces fuel lines for NASA.
While we are on the unique, high-tech discussion, the vacuum breaker La Marzocco uses is made from high-tech memory metal. The old-style weighted dangling valve is long gone. This unit does not rely on boiler steam pressure to 'snap' and hold a weighted valve closed. When the boiler reaches a given temperature the metal in the breaker changes shape closing the boiler. The current production GS3 and Linea Mini use the same steam wand and vacuum breaker.
Clearance under the portafilter is a little tighter than some machines. To maximize the clearance, you can remove the spouted insert and use the portafilter bottomless. The group will take a standard LM portafilter but I noticed a couple of issues. First, the addition of the spout and deep base of a standard portafilter makes clearance quite tight. Still enough for a normal demitasse cup but anything taller will require you to tilt it in and out. The angled handle on the standard LM portafilter also gets in the way. The downward slope puts the portafilter handle in the way and you may find yourself smacking your cup against it. The standard Micra portafilter has a straight handle, probably because of that. Measuring from the bottom of the bottomless portafilter to the drip tray I get 4 inches of clearance.
I have not had any issues with clearance using the included portafilter. All of my espresso and cappuccino cups fit without issue. After a couple of days of use, the perceived short working space became less of a concern. If you plan on sticking a 20oz tumbler under the group for milkshake-sized drinks, you will have a problem but the machine was never designed for that kind of use. For reference, a 'standard' 16oz mug just fits under the portafilter.
- cannonfodder
Forgot to mention the Micra has 2 LED lights on either side of the brew group that illuminates the drip tray when pulling a shot. It seems like a trivial little item but is very nice. The reduced clearance between the brew group and drip tray means overhead lights cast a shadow on your cup. The little lights are bright enough to fully illuminate your work area. You can even pull shots in the dark if you were ever driven to that state by caffeine deficiency.
- cannonfodder
There have been a lot of questions about the drip tray size and if it can accommodate a scale. The Acaia Luna scale fits the drip tray with room to spare. You might even think someone at La Marzocco thought 'Hmmm, wonder what would happen if we put a scale on the drip tray' while the machine was in R&D.
There is ample clearance. The minimal height of the Acaia scale leaves plenty of clearance for both a demitasse and a cappuccino cup. The scale is centered on the drip tray with a little space still open behind and in front. I have the little silicone heat mat on the scale as well. I will note that the top cover of the machine would not be an ideal storage location. That is directly over the brew group and gets quite warm if you run the machine for long periods. I have it set to power on at 7 am and off at 6 pm so I run it all day, 7 days a week and that top gets as hot as the cup warmer. Not burn me hot, but if the Acaia is heat sensitive enough to provide a silicone heat shield for pulling shots, setting it atop a heat source for storage may not be the best idea.
- HB (original poster)
- Admin
That will teach me for not reading the owner's manual. This is what it looks like:cannonfodder wrote:Another interesting note, the app is also a shot timer. With the app open, when you start a shot the screen changes to a shot timer. Handy feature since the Micra has no integrated chronograph for shot time.
And one of today's espressos:
I fumbled for the camera, hence why the crema had started to settle. Next up is a video with me and Martin Keen; he's acting as the new "newbie" home barista and he'll compare/contrast the Linea Micra with a well-known E61, the ECM Synchronika.
