Buyer's Guide to the Gaggia Achille - Page 23
Behind the scenes of the site's projects and equipment reviews.
cannonfodder (original poster)
#221: Post by cannonfodder (original poster) »
timo888 wrote:Yes, but in Jim's humpbacked whale of a profile, the temperature does not spike into boiling water territory.
The temperature profile is a bit deceiving. I can assure you that the shots it produces taste much better than that graph suggests. Going strictly by the numbers, the shots the Achille produces would be a melange of sour and bitter swill, not the sublime cup it produces.
Like Jim's experience with his Elektra semi autos pressure settings, based on the numbers it should produce a harsh shot but instead it gleefully produces a wonderful elixir.
Dan has the uber geek espresso kit but I do have a Fluke 52-II two channel thermocouple thermometer and a Fluke 189 datalog meter in transit. I have to have a few toys. I was going to play with an over the lip and up through the puck thermocouple measurement when they arrive and I return home. I am out on business through the weekend starting tomorrow evening.
If you reduce the Pstat setting down to 1 bar you would get much more recovery time at the expense of steam. The shot in the video was too hot and went down the sink, but I went slow just to show the process for the video. I find the machine works best with lighter northern Italian roasts which tend to prefer a hotter extraction. My one dark roast was a challenge.
To answer hbuchtel, yes, adding cold water will draw out the recovery. That was a trick I noted in a previous post. When dealing with blends that prefer a lower temperature, I would fill the reservoir with water from the refrigerator. That tasted like it lowered the temperature by a couple of degrees. However, if you normally drink dark roasts that work best in the 198-200F range, lowering the Pstat may be a better option, or try the power off, flush and pull trick HB mentions.
another_jim
#222: Post by another_jim »
In a manual lever, one can use the lever to vary the pressure, or more importantly the flow rate, to compensate for the temperature. If the temperature starts low, a longer preinfusion will still transfer the flavors from puck to water, if it gets hot in the end, one can finish extra fast (or perhaps extra slow? I'm amazed to find myself without any intuition on this). These are adjustments any competent home barista will make the first time she or he takes the machine for a spin just by tasting successive shots.
Jim Schulman
timo888
#223: Post by timo888 replying to another_jim »
That one of Dan's "adjustments" was to turn the machine off during an extraction tells me that either his tongue or the data or both were telling him the machine's intra-shot temperature can sometimes get too hot for a good extraction, despite the pre-pull cooling flush.
My hypothesis is that the double-pump on the preinfusion is what may be causing the heating element to come on mid-shot, driving the temperature out of the sweet and into the bitter range. I would like to see a 26-second or 30-second plot where the lever is raised, depressed gently part of the way for the preinfusion ~5 seconds, and then, instead of raising the lever again to draw more water, press it down to pull the shot. This will reduce the volume of water, of course, and so the dose should be reduced accordingly.
Regards
Timo
#224: Post by cannonfodder (original poster) »
Just got home from a week of business travel. My bottomless portafilter is here, my K type datalog meter is here and my other Fluke 52 (J, K, T and E type two channel thermocouple meter) will be arriving soon.
I will try to shoot a couple of videos and I am going to botch together a two probe LM basket to try to get some in the puck measurements. The buyers guide editing is also in full swing so time is tight. I only have a week at home (which includes my daughters 12th birthday) and then back on the road for business.
timo888
#225: Post by timo888 »
Dave,
It's hard to tell from the videos, of course, but since you're no bantam-weight, when you really lean on the lever with your upper body, you are applying quite a lot of force to the piston and creating considerably more than 9 bars of brew pressure. I'd estimate you've been extracting at 11 bar maybe even 12 bar. The Achille's piston is relatively small at 44mm and yet the mechanical advantage of its lever is greater than the Cremina's, for example.
Achille Piston Diameter: 1.73 inches (~44mm)
Piston Surface Area: PI * (.865 * .865)
9 bar = ~ 130psi
130 psi = REQUIRED POUNDS OF FORCE divided by ( PI * (.865 * .865) )
130 psi = REQUIRED POUNDS OF FORCE divided by ( 2.35)
305 # = REQUIRED POUNDS OF FORCE
Judging from the length of the lever and the distance between the pins, and adjusting for the fact that your grip on the lever handle is not precisely at its extreme tip, let's say the lever gives you only eightfold or ninefold mechanical advantage instead of elevenfold.
305 divided by 9 = ~34 pounds of force required on the lever handle to produce 9 bar
It seems you're putting a lot more than 34 pounds on that lever.
If the lever's mechanical advantage is only eightfold:
305 divided by 8 = 38 pounds of force required on the lever handle to produce 9 bar
It seems you're putting quite a lot more than 38 pounds of force on the lever handle too.
Regards
Timo
#226: Post by cannonfodder (original poster) »
Looks can be deceiving. While I do lean into the handle, it is controlled. I am not doing an 800 pound gorilla one arm hanging in the air (BTW I am 210lbs not 800). When I originally received the machine I used a high tech bathroom scale to measure my pressure. According to it I am getting somewhere in the 40lbs range give or take 5lbs. I simply leverage my weight to obtain a smoother more controlled pull rather than relying on sheer strength.
Quite honestly, the exact amount of pressure is immaterial. I measured it at around 40 lbs, then tossed the scale back in the bathroom and adjusted the machine based on taste. Just like tamping, the 40 lbs mark is merely a suggested starting point not a rule. Each person will adjust their pressure based on blend, taste and physical ability. Just like the thermal measurement Dan made, which shows the intra shot temperature spiking, I don't always believe in the numbers. I can assure everyone that the end of the shot is not hitting 210+F. A bumble bee should not be able to fly given its large body to wing ratio, but it does. The Achille or Elektra semi auto should not make a good shots based on the numbers, but they do.
I can assure everyone that Dan and I have tried to present the machine accurately and openly. I have pointed out its strengths and weakness without bias and you the reader must decide for yourself if you trust our observations and judgments. Realizing that this review will effect many purchasing decisions I have thoroughly thrashed the machine to within an inch of its life to test the boundaries (read this as used hard but not abused).
The technical side of my vocation is interested in the science and mechanics behind the machine but the artistic side of my brain screams who cares enjoy the magic, and I am. While I do plan on tinkering with some measurements, I would not trust them beyond what I taste, and what I taste is good.
#227: Post by cannonfodder (original poster) »
Blonding sucks, but was only my second shot from that blend, it needs more dialing in. Diagnostics will be posted in the Videos of espresso extractions thread.
I promised the good bad and ugly. This one definitely started good, went bad then turned ugly.
«missing video»
#228: Post by cannonfodder (original poster) »
I had an interesting thought a couple of days ago while cleaning the group on the Achille. Since the machine works like a typical heat exchanger pump machine, why not do a portafilter wiggle and backflush of sorts?
Since you can partially open the group to relieve pressure, why not use a backflush basket with a little JoeGlo to spoof the machine into a pressurized wash. So I tried it while the machine was cold just in case things went awry. If you have ever been splashed in the face with 190+F water you understand, if you have not than heed my warning. Always try something new with a COLD machine, trust me, hot water in the face hurts.
So I took my backflush basket and popped it into my portafilter. I gave the lever a 1/3 stroke until it firmed up and stopped. Then I slowly rotated the portafilter until I was greeted with a whoosh of cold water. The water jets around the top of the portafilter and lug raceways in the group. The water runs down the portafilter and into the drip tray. Hmmmm, interesting.
So I repeated the above procedure with a hot machine. I added just a bit of JoeGlo to my basket, gave the lever a little tug to fill the blank basket with hot water (that dissolves the detergent so it flushes through the group better). Then I lock the portafilter into the group and tug until the lever stops. Give the portafilter a quarter twist and the hot water and detergent blows out some coffee residue around the portafilter and into the drip tray. I repeated the flush twice then finished with a portafilter wiggle. While holding the portafilter and partially inserting it into the group, I pulled the lever and wiggled the portafilter back and forth to further clean the gasket and raceway.
Wipe off the group, rinse out the blank basket and repeat with clean water to rinse. I would still remove the shower screen and dispersion block for monthly cleaning. This may work well as a weekly cleaning regiment to keep the machine fresh.
another_jim
#229: Post by another_jim »
cannonfodder wrote:I had an interesting thought a couple of days ago while cleaning the group on the Achille. Since the machine works like a typical heat exchanger pump machine, why not do a portafilter wiggle and backflush of sorts?
Um, because there's no 3 way valve to keep clean? If you want to clean this machine's entire waterpath, some cleanser dissolved in water in the tank along with some lever action will flush the entire system. If you do that with a machine that has a three way (boiler autofill disabled), the "forward-flush" would never get at the crud accumulating on the other side of the three way valve.
Jim Schulman
#230: Post by cannonfodder (original poster) »
I actually meant to call out the fact that it does not have a 3 way but thought that was understood so I did not.
I am not cleaning the water path as one would have to do with an E61. My thought was to flush some of the buildup out of the nooks and crannies in the group. If you use the partial portafilter removal method to depressurize after a shot (as I showed in a video in a previous post) a lot of grounds end up blown into the lugs and the little crevices around the shower/dispersion block.
In order to clean it, you need to take the screen and block off. If you flush/PF wiggle like this, you essentially power wash those nooks and crannies out. While not a substitute for removing the screen and block for a good cleaning and scrubbing, it does help cut down on the grunge between cleanings.
