Which, If Any, Of These Three Tampers?
I'm coming to the conclusion that, better than a distribution tool and better than a WDT tool + distribution tool, is a WDT tool + traditional tamper. But the tamper that came with my the Bambino Plus is small and light. I'm thinking I want something with a bit more heft to it.
I've narrowed it down to the following three candidates on Amazon and cannot come to a decision:
Thanks!
- Omgogo Coffee Tamper 53mm
- LuxHaus 53mm Espresso Tamper
- Motta 8140/M Professional Flat Base Coffee Tamper, 53mm
- #1 - Its price
- #2 - Its size (I have large hands), average rating, & number of reviews
- #3 - Its aesthetics & being made in Italy
Thanks!
- BaristaBoy E61
I might choose the Motta Tamper as the wood might feel, 'softer' in my hand. It looks more ergonomically designed and might have a shorter handle that I would also prefer.
Motta has been around for a long time and makes excellent products. I would also definitely recommend an adjustable Distribution Leveller Tool as well. I've found that it made a big difference in puck prep with a lot less spritzing when using a naked portafilter. That also means a lot less cleaning up of the machine too!
It's all very subjective; there's no running off the road into a ditch here.
YMMV
YMMV
- Jeff
If a plain tamper, I like my fingertips on the top edge of the tamper base so I can feel the basket rim and know that I've tamped squarely. It would come down to feel between them. One of my favorite tampers is a relatively cheap one I bought probably over 15 years ago. It just is the right height for my fingers and is a reasonable weight, not overly light or heavy. At least for Amazon Prime members, there's "free returns" on the first two.
- sweaner
They will all work the same. I like the Motta for the wood.
Scott
LMWDP #248
LMWDP #248
As I noted in my OP: I have one. I'm not certain it's doing anything for me that I'm not achieving with my WDT tool & regular tamping. I suppose I'll have to eventually break down and acquire a bottomless PF to find out for sure, though.BaristaBoy E61 wrote:I would also definitely recommend an adjustable Distribution Leveller Tool as well. I've found that it made a big difference in puck prep ...
Yes, I like that and the fact it's made in Italy, rather than China. The Motta is the way I was leaning before. Now I'm leaning even more strongly toward it.sweaner wrote:I like the Motta for the wood.
Thanks for the comments, guys!
Personally I wouldn't want to go back to a non self leveling tamper. One less thing to worry about. I have a Kafatek Levtamp but there are others with similar designs.
- Jeff
I agree with the value of a square-to-basket tamper. If budget permits, that would be my choice. With a lesser budget, it comes down to ergonomics on being able to tamp squarely and reliably. Having used all three, I didn't find enough value in a force-indicating ("calibrated") tamper over a plain tamper, unless it is also square-to-basket.
Some supposedly "calibrated" tampers put the spring in the wrong place and only increase the force that needs to be applied, rather that indicating how much is being applied to the puck.
I am of the plain tamper school -- you learn to tamp level with a little attention. Of the one's you show I would probably pick the Motta, but I have no experience with either. I have a Cafelat, which has served me well. They make a 53mm but it's $48 according to Chris Coffee's website. EDIT: Cafelat store lists one for $35 - not sure what shipping costs.
- sweaner
I use an inexpensive leveling tool, then tamp. No need for a self-leveling tamper.jgood wrote:I am of the plain tamper school -- you learn to tamp level with a little attention. Of the one's you show I would probably pick the Motta, but I have no experience with either. I have a Cafelat, which has served me well. They make a 53mm but it's $48 according to Chris Coffee's website.
Here is one for the OP:
https://smile.amazon.com/Distributor-MA ... 170&sr=8-8
Scott
LMWDP #248
LMWDP #248
Thanks for the tip. I've looked at them. The concept is attractive, but I can't see spending that much for a tamper.PIXIllate wrote:Personally I wouldn't want to go back to a non self leveling tamper. One less thing to worry about. I have a Kafatek Levtamp but there are others with similar designs.
That's my expectation.jgood wrote:I am of the plain tamper school -- you learn to tamp level with a little attention.
Thanks for the lead. I looked. Doesn't appear to offer any advantages over the Motta, and it ships from Hong Kong.jgood wrote: I have a Cafelat, which has served me well. They make a 53mm but it's $48 according to Chris Coffee's website. EDIT: Cafelat store lists one for $35 - not sure what shipping costs.
I have that exact leveling tool already, but thanks, anyway.sweaner wrote:I use an inexpensive leveling tool, then tamp. No need for a self-leveling tamper.
