Torn between completely different espresso machines
borisp
#1: Post by borisp »
Hi,
I've been lurking around for perhaps too long ^_^
I have sold my Gaggia Classic Pro because I wanted to upgrade to a Lelit Elizabeth. Life happened, the budget was allocated elsewhere and meanwhile, we're drinking pour-over coffee which is perfectly fine, but my wife desperately wants the Cappuccinos back. With our Gaggia Classic we primarily made Cappuccinos and Americanos.
I have a Eureka Specialita grinder and am now contemplating an espresso machine purchase.
Our budget is still not 100% defined. Those are the 4 main contenders:
1) Breville Bambino plus - because it's cheap.
2) Lelit Elizabeth - this will be the top of our budget with a stretch.
3) Mara X
4) Ponte Vecchio Lusso I/II
I hate the first option because being prone to upgraditis, I think I'll grow to hate the machine.
Lelit Elizabeth seems like the wisest choice, it's a dual-boiler, it might resemble my previous workflow with Gaggia Classic pro which is to pull a 18g with a double spouted portafilter and have 2 cups of cappuccino from 1 pull, essentially.
Elizabeth's steam power is highly impressive to me, coming from the Gaggia.
The Ponte Vecchio Lusso
This is a semi-dream. I really like levers. I mean, I really like levers when I see them in YouTube videos :D
I understand the max shot capacity is about 14g of coffee, correct? so, about 28-30g of espresso?
I'm trying to understand whether this will eventually turn out to be a major flaw for us.
I mean, the only "flaw" is that I'll have to pull 2 consecutive shots as opposed to just one. However, I'll have a bit more espresso in each cappuccino eventually and thus a more balanced and flavorful cup of coffee... so.. then I think, well, maybe the pvl2 would be perfect for pulling two shots *almost* simultaneously?
Also, how's the steaming power of the PVL? it should be at least as powerful as the Lelit Elizabeth/Mara? I really don't know sorry if that's a silly question :-)
To Summarize, my most important factors in a machine:
- I don't want to upgrade/buy new at least in the next 3 years.
- Must be able to serve 2 cups of cappuccino in a relatively pleasant experience.
- Steaming Power. I quickly outgrown the slow steaming experience with GCP.
- I'd like to experience with Light/Medium roasts as well.
Finally, the reason the Mara X is on the list is due to me being located in Israel and only the MaraX is available from a local reseller.
Purchasing the PVL, Elizabeth or Bambino will require ordering internationally.
the PVL is sold by a shop called lagondola from Italy, the Elizabeth and Bambino from Amazon.
What would you suggest?
baldheadracing
#2: Post by baldheadracing »
I'd pick the Mara X on local availability alone. If something goes wrong, then it'll probably be within the first few days of having the machine, and shipping to another country can be a pain. Regardless, I'd probably still pick the Mara X. Reviews of the machine are good and there is plenty of discussion here about the machine. I haven't used the Mara X, but the Mara was a small-footprint machine that offered great value. A little on the noisy side, but small vibration pump machines do tend to be noisy. (Modifications can address this, but that's a separate issue.)
The PV Lusso is an interesting machine, but I would (and did) take an Elektra Micro Casa a Leva over it. Steam should be no problem with Lusso's 3l boiler, but that big boiler also means that the machine will take quite a while to come up to temperature (unless you keep the water level in the boiler low). The upcoming Odyssey Argos and Londinium Vectis might also be of interest.
Good luck!
Ad-85
#3: Post by Ad-85 »
Ponte Vecchio Lusso 2G would be more fun to use than other "press a button" machines
LMWDB #691
LeverHeads on Telegram
borisp (original poster)
#4: Post by borisp (original poster) »
I have read about 20 minutes warm-up for the Ponte Vecchio here on the forums.
In any case, I guess I underestimate the importance of having a local dealer, although the experience of local coffee hobbyists with local suppliers' and resellers' support is subpar (to say the least) and many prefer to order internationally, I do not know, however, how they manage repairs/parts in case of serious trouble.
I have another option to check out a used Lusso: it's 12 years old, 3 years ago boiler changed, descaling maintenance routine 1.5 years ago. 1 group, if the price will be low enough, I might consider that option and begin saving up for a rather serious commercial lever machine.
If not, I guess the MaraX will be the wisest choice. paying the same $$ for a new 2-group PVL (internationally also) would be too much of a shot in the dark for me, and from what I understood (after devouring the forums) there aren't any serious lever machines in my price range (Strega, Londoniums, Quickmill Rapida, Izzo, etc.). For reasons I cannot fully express and articulate myself, I don't want a La Pavoni or Elektra as my main daily driver machine, perhaps my wife's objections contribute to that significantly :D :D
Also, our local prices are significantly higher than most EU. MaraX is more (about 100$ more) expensive than ordering Elizabeth internationally.
baldheadracing
#5: Post by baldheadracing »
The used Lusso would be interesting and a good introduction to spring levers. You'll get used to the 14g shots :D. Hope it is at a good price.
Mara X is about $100USD less expensive than the Elizabeth in the USA.
pizzaman383
#6: Post by pizzaman383 »
With a two-group Lusso you could pull two 14g shots at the same time.
Curtis
LMWDP #551
baldheadracing
#7: Post by baldheadracing replying to pizzaman383 »
There's only one HX and thermosyphon circuit though - the groups bolt to a manifold that splits the same boiler, HX, and plumbing as the one-group. As a result, I'd guess that the two groups are more for sequential rather than parallel usage.
#8: Post by borisp (original poster) »
Would you still choose Mara given the Elizabeth is slightly cheaper, although not available locally?
baldheadracing
#9: Post by baldheadracing replying to borisp »
I wouldn't choose either, but I'm in a different market and the Breville Dual Boiler is currently about $300USD lower than the MaraX/Elizabeth :).
But back to you:
- what types of coffees and roast levels do you drink?
- what would be a typical weekday coffee-making routine? Times, how many, etc.
- what would be a typical weekend routine?
- when friends/family visit, then do you want to make coffee for them?
At this level of investment, I feel that getting the best machine fit is more important than price differences.
#10: Post by borisp (original poster) »
- We make 2 americanos in the morning, currently it's drip coffee. We have only experienced dark roasts but we're much open to experience new, light/medium roasts.
Afternoon, we make 2 cappas. In the evening sometimes we make 2 more cappas, although I used to make myself a small drink (cortado?)
With guests we make espressos & lattes.
From time to time I tried drinking espressos I pulled with Gaggia Classic, but didn't like them - they were too harsh in general and I wasn't able to enjoy them and didn't feel their distinctive flavors. With pour over I definitely feel the nice acidity and sweetness that comes out of my coffee, it's very pleasant.
On weekends, the routine is pretty much the same.
Fwiw, our cappuccino is around ~180ml, so perhaps not the traditional 150ml capp.
