Professional Hand Grinder
Hello fellow coffee lovers,
a friend and I are currently are developing the crazy business idea of making professional class espressos on a coffee cart without electricty.
We have already selected the Bezzera B2013 AL that is actually designed for working properly with gaz only (how smart from Bezzera) and that is quiet cheap for a commercial use. But we are still struggling on picking up the grinder. My choices went from ROK grinder to Kinu M68 and after reading an amzing post from DJR about the Spong mills, I thought why not using a proper vintage grinder. As you understand, we want something heavy duty, stationary, that grinds fast, in large quantity and fine enough for espresso.
What do you guys think? Any suggestions on the grinder? Espresso machine? Business?
Thank you so much for reading .
From Brussels with love!
- GregoryJ
Hi Guigui, a gas powered espresso machine, that sounds cool! Have you ever ground for espresso by hand? As much as I love hand grinders, I cannot recommend doing more than a couple at a time. I'm sure the upright ones are a little bit easier, but I've seen people sell their HG-1 grinders due to strain or fatigue.
I seem to remember a similar thread awhile back and one suggestion was to fabricate a grinder around a stationary bike. I thought that was a brilliant idea. Either have the customers grind their own or one of you could be the "grinderman" and pedal and tamp alongside the cart.
There is a long time member here who motorized his HG1. Of course, it ran on electricity, but I wonder if it could be battery powered?
His HB user name is fotondrv. Search him here, and PM him...perhaps he could design something for you.
Gregory, actually there are a LOT of machines built in the 50's and 60's that run on gas.GregoryJ wrote:Hi Guigui, a gas powered espresso machine, that sounds cool!
- Stephanus
I am not sure what your budget is but the Velopresso (Velopresso dot cc) coffee trikes are awesome. They incorporate a pedal driven grinder in the system along with a gas fired spring lever espresso machine. The pedal driven grinder is much faster than grinding by hand.
The vintage Spong grinders can grind for espresso but in my opinion the taste does not get close to modern espresso grinders. Those grinders generate a lot of boulders and a lot of fines at the same time and can choke a machine with one shot and it can flow too fast with the next shot. This is based on my experience wit a No1 and No3 Spong.
Only a surfer knows the feeling
We used to use a hand grinder and a cordless electric drill, but the volume was low. But even for more volume, a few charged batteries can last all day. As for the grinder, we just used a handmade Turkish grinder held in one hand with the drill in the other. For volume, the issue would be hand fatigue; I'd look for a grinder that would chuck easily into the drill, be easy to mount on some surface and be easy to fill/empty. Perhaps you could mount both the drill and the grinder on a piece of plywood. An Orphan Espresso Pharos might work like this. And, being a quality grinder, would produce excellent shots. If you only mount the grinder, then I think I'd use one of those springy extensions to minimize the wear on the upper grinder bearing.
If you wanted a pedal driven grinder, a HG-1 would be easy to mod as the handle is in the correct orientation.
Ira
Ira
If you don't want to sit down on a bike every time you need to grind you could use a treadle from a standing position. A treadle with a big fly wheel would be very easy to adapt to an HG1.
