Professional espresso machine for outdoor event - Page 2
- drgary
With a two-group lever you can keep shots coming. You'll probably turn many into milk drinks.
LMWDP#308
LMWDP#308
What resources will you have? Running water? Electricity?
What budget? Will you rent or purchase the equipment?
I don't know if buying an expensive machine to fulfill your requirements will be a profitable experience for you. How many shots can you do in 2 hours and what can you charge to make it a worthwhile event for you? You are looking between $4-6 K to start up on the cheaper side, and those machines are heavy. Good luck with whatever you decide.
- drgary
I wonder if there is a way to rent a professional machine for this one event? A caterer could provide it to you.
LMWDP#308
LMWDP#308
- homeburrero
Beware that many prosumer single group machines are not tuned to crank out consecutive shots without waiting for the group temperature to recover.A-String wrote:- One group since only one person will run the machine and we understood we are not gaining any output improvement with a second group
As others have said, two or more groups will allow a single barista to crank out shots much more quickly.
For fun, watch these YouTube videos of legendary baristas handling the rush on 4 group levers:
Rosario at Bar.De.Ga in Napoli
Dritan Alsala in Düsseldorf
Pat
- drgary
+1
My suggestion of a two-group lever comes from visiting the Blue Bottle kiosk in the San Francisco Ferry Building years ago. They had a window with a Kees van der Westen three-group lever. A single barista usually had two groups running in sequence. He would prep and load a shot and start a pull, and while that was proceeding, he would prep, load and pull the next shot. Milk steaming happened in between. With the constant flow of customers and shot-pulling, I can't imagine the groups not being temperature-stable.
LMWDP#308
LMWDP#308
