Orphan Espresso LIDO for espresso? - Page 2
I have usd a lido 2 for years with a pavoni and cremina, works just fine. I use a sharpy dialing in. Do I want finer threads, no, not for me.
In my experience, any of the LIDOs are not ideal for espresso. At finer settings, I've always had burr rub and have had difficulty aligning the burrs well enough in the espresso range. With the locking ring design, it's also more difficult to get very precise adjustments.
The king of small burr hand grinders is the Kinu M47. The most cost-accessible (by far) titan grinder is the Pharos.
A somewhat cheaper but high quality grinder is the Helor 101.
A very compelling grinder for espresso at a fantastic pricepoint is the Knock Aergrind. History tells us that Knock makes very high quality and well-aligned grinders which are very espresso-capable and with easy grind adjustment. The only limitation of the Aergrind is small capacity, but it's plenty for espresso purposes. I've not used the Aergrind, but I have had the Feldgrind which is essentially the same grinder but a bit bigger, using the same burrs. https://prima-coffee.com/equipment/knoc ... bUQAvD_BwE
If I were you and could spend ~$350, I'd go for either Kinu M47 vs. Pharos.
If I were on a tighter budget, I'd go for the Aergrind.
For me, the LIDO series is great for brew grinding, but there are many better choices for espresso grinding out there.
Thanks. I have other grinders for drip and Aeropress so this will stay set for espresso. Just not completely cutting it for espresso. I have just started with a Flair and will probably want to move up at some point so why not get the grinder with expansion in mind.
- baldheadracing
I have an Aergrind and a Hausgrind (and a Lido2, and Pharoi, and ...). There is no comparison. As has been documented in the Aergrind thread, the axle (and thus inner burr) mounting/bearings/alignment are not at the same level as Knock's other grinders - and, in my experience, the play gets worse with use. The Aergrind is probably still the best grinder that fits inside an Aeropress at its price point, but if one removes those qualifications, I would say that there are grinders that produce tastier results - including MBK's other grinders.randyh wrote:A very compelling grinder for espresso at a fantastic pricepoint is the Knock Aergrind. History tells us that Knock makes very high quality and well-aligned grinders which are very espresso-capable and with easy grind adjustment. The only limitation of the Aergrind is small capacity, but it's plenty for espresso purposes. I've not used the Aergrind, but I have had the Feldgrind which is essentially the same grinder but a bit bigger, using the same burrs.
As the OP is after espresso grinding, I would never recommend an Aergrind for espresso - besides the grind quality, I found that the adjustment was just not fine enough, nor repeatable enough. I'm not knocking Knock - I used my Hausgrind as my office espresso grinder for years, and that was with a vibe pump machine with no over-pressure valve, not a relatively-forgiving manual lever machine.
Thanks for clarifying this. Unibody frame with dual bearings seems like a foolproof design but I guess not.
"Any of the Lidos are not ideal for espresso"??? Really???In my experience, any of the LIDOs are not ideal for espresso. At finer settings, I've always had burr rub and have had difficulty aligning the burrs well enough in the espresso range. With the locking ring design, it's also more difficult to get very precise adjustments.
I have had the OE Lido 2 since it was released, and it has been great for espresso, pour over, AeroPress, and Moka pot. Also, it is pretty easy to get precise adjustments.
LMWDP #115
- yakster
I also haven't had any issues with burr rub or precise adjustments with my Lido 2.
It's my regular work / travel grinder.
-Chris
LMWDP # 272
LMWDP # 272
- baldheadracing
Note that not everyone is experiencing this. However, some are, and people have gone to the effort of retro-fitting other bearings with positive results. This points to a quality issue, not a design issue ... and Knock's customer support is not even remotely close to industry leaders like Baratza.randyh wrote:Thanks for clarifying this. Unibody frame with dual bearings seems like a foolproof design but I guess not.
Thanks everyone. I'm looking into the purchase but am wondering if there is anything better at the same sort of price point. I don't need the capacity that the Lido has so smaller grinders may be an option too.
If the m47 is too expensive I'd implore you to consider spending a bit more and go for the Helor 101 or Kinu m47 traveler. Both I believe will be much better for espresso
