New mid level espresso grinder opinions sought
Hi All,
Its Yet Another What Grinder Question! But perhaps my requirements are a bit different than others. I unfortunately don't have access to a nice retail shop where I can check things out, so its a bit of a leap of faith.
I've used a Mazzer mini E for about 10 years, before it fell of a truck while moving, and the last several years I've been using a Sette. While the Sette is remarkably good, I honestly can't take the sound in the morning. I actually hit the grind button and walk away as quickly as possible to not get inundated with the noise.
With that in mind, I'm looking for a new on demand grinder, preferably in the $1000 to $1200 level and am soliciting advice. My needs:
* I will never/do not care about single dosing
* I do want a quieter grinder
* I do want a long lasting/well manufactured grinder
* I like a nice interface (easy to set dose & grind)
* I don't actually care about minimal differences in grind quality. Honestly I just want to make some tasty drinks and move on. Life is busy.
* It has to fit under a standard US cabinet (~17 inches and some small change)
So, discounting ultimate grind quality, what would be a really nice grinder to live with? Clean, easy to work with, decent looking. I've looked at the Ceado 37j, the Atom 65, ECM... I could push the price if necessary, but I'm not sure that with my requirements there is a huge amount of gain for the extra outlay.
Cheers!
Cheers!
.... or a K10 and go find that guy in Honey I Shrunk the Kids and have him reduce it a little
- chopinhauer
Eureka Atom. Good, not too large and quiet as far as grinders go. It's got noise insulation.
LMWDP #027
My K-30 with a short hopper was really quiet. It is a little bit over your budget. But, not by much.
I have the Atom Specialty 75 and can highly recommend it.
I think it meets all of your requirements.
- redbone
Do you have a preference for burr type flat or conical. Budget, size, single dose or not, these play large factors here.
As far as flat grinders within <$1500.
Eureka
65E
75E
Rocket Fausto
Ceado
E37J
Eureka
65E
75E
Rocket Fausto
Ceado
E37J
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
Thanks guys. The Atom (or atom 65, I don't see the 75 available in USA) seems like it fits most of the requirements. I suppose I am just a bit turned off by some negative commentary around on the forums. That could be just the concentration of bad opinion that often happens on Internet forums though.
The K30 sounds like a good grinder, but is 50% over budget, and seems quite hulking in photos. The wife may object.
I think I got most of those in the initial post, but a couple more details couldn't hurt. Flat/conical would fall in my 'I don't care' camp. I also only grind espresso, and all of my coffees are easy (no single origin, no light roasts). Don't get me wrong, I buy quality coffee, and like quality drinks, but my passion may not go as far as othersDo you have a preference for burr type flat or conical. Budget, size, single dose or not, these play large factors here.
- slipchuck
You will find something negative about everything as people usually harp on the negative not the positive.nicholasr wrote:Thanks guys. The Atom (or atom 65, I don't see the 75 available in USA) seems like it fits most of the requirements. I suppose I am just a bit turned off by some negative commentary around on the forums. That could be just the concentration of bad opinion that often happens on Internet forums though.
I think the Atom would be an excellent choice for your needs
Good luck!
Randy
