Most inexpensive grinder for espresso
hi guys so I the cheapest grinder I can get to pull my wife decaf espresso, I have a good grinder for the good stuff but I need this for the wife, any suggestions?
Have you tried single dosing with your Ceado grinder? That's what we do at home with the Eureka (which isn't even designed for it). I'm able to swap out whatever coffee. Dialing in is slightly different for each one, but I don't really stress about it.
If you're gung ho on a separate grinder, what's your budget? Cheapest possible is likely going to be a hand grinder, maybe a Hario.
thanx for ur response, and I been single dosing for the last month and boy is it inconsistent I mean like very inconsistent I gave up on it and now put the hopper on my Ceado e6p hence why I need a grinder. I was hoping for an electric one but I think handheld is going to have to be the one to get. any recommendation on hand grinders ?
Hey Jesse,
There are a number of really good hand grinders, most of which are detailed here: https://coffeegeek.co/en/list-premium-h ... -grinders/.
Based on the many threads and great feedback of Home-Barista members, the top two I would consider would be the Apollo B-Plus and the Kinu M47. I've used my M47 exclusively for the past three years and continue to enjoy it.
Breville Smart Grinder Pro.
Ascaso I mini I1
Timemore Chestnut CS
Ascaso I mini I1
- cerone
If I absolutely needed a dedicated decaf grinder I'd probably get a Sette.
One good option is the 1Zpresso Jx Pro,159 dollars,a manual grinder really good for espresso with 200 clicks, consistent grind, 48 mm. steel burrs, and you can grind 15 grs. of beans in 30 seconds. I think is in the budget side, and you have a quality grinder for espresso.
- slipchuck
Ascaso I mini I1
Randy
Randy
If cost is a concern, I would recommend an 1zpresso JX Pro or an Aergrind for good quality at a reasonable price. If you really want to save, buy a Porlex.
- redbone
Capresso Infinity similar to Baratza Encore but with added timer and Swiss made conical burrs according to their specs. Some retention but not noticeable in pour over vs espresso.
Semper discens.
Rob
LMWDP #549
Semper discens.
Rob
LMWDP #549
